Forum: µC & Digital Electronics struct within multiple struct causing problems
von John M. (215)
I have a struct which is beeing included to other struct in other
modules, such as StructA.StructB.ElementofB is possible.
This is done for multiple modules, and each module has the .h file of
structB included.  But for some reason am i getting compiler errors
which says that structB is an undefined type, eventthoug i in my IDE can
see that it is declarated correctly.
Why is it saying that the type is undefined eventhough i've included the
.h file??
von RON (Guest)
Maske an example of the complex struct with same datatypes!
von John M. (215)
typedef struct{
int start;
int stop;
int lap;
} a;
typedef struct{
a A
int car;
int postal;
} loser;
typedef struct{
a A
int don;
int son;
} more;
each struct is in it's own .h file. i've just included .h of struct a on
all them.
: Edited by User
von Daniel A. (daniel-a)
I can't find a mistake in the example, i think the problem is somewere
else. How is the exact structure of the files, in which order are
#include and #ifdef - #endif and in which files? Try to preprocess the
files only, then something may be clearer. (gcc -E file.c)
von K&R reloaded (Guest)
I can!  What about a semikolon after the "a A"  line ?
von John M. (215)
Well. that's just because i just wrote some random ones here..
they are added in my code.
von Rolf Magnus (Guest)
You are not supposed to write some random code for this posting, but
something that you tried and that actually contains the problem you're
experiencing.
