Forum: FPGA, VHDL & Verilog case port map
von bob (Guest)
Hi all!
I have an idea for a code I am writing but I don't know if it's
possible. Let me explain:
I want to connect a component with an other in function of a signal.
A thing like this:
case wave_type is
       when sinus =>  V_pos: sinus_wave generic map();
                                        port map();
                      V_neg: sinus_wave generic map();
                                        port map();
       when square => V_pos: square_wave generic map();
                                         port map();
                      V_neg: square_wave generic map();
                                         port map();
      when ..........etc
I have tested that but a signal expression is expected instead of port
map...
Do you know a solution to get what I want? Thank you
von ChristophZ (Guest)
If you would like to change the component used in your code when your
design is synthesized then you can achieve it with the "generate"
statement.
If you would like to change the used component during runtime (when your
hw is running) you need to instantiante all components and you need a
multiplexer to select the desired output (for example with a case
statement like in your code).
von bob (Guest)
> your
> statement.
It's for simulation only. Can you explain what you mean by "generate"
statement please?
One of the first links my search engine presented me:
http://vhdl.renerta.com/mobile/source/vhd00033.htm
