Forum: µC & Digital Electronics Convert Unsigned 8 bit integer to a string ?
von John M. (215)
How shall i convert a unsigned 8 bit integer to a string without using
any libaries.... Only self written functions.
von Max H. (hartl192)
If you use C:
  unsigned char number_txt[4], hundred=0, ten=0;
  while(1)
    if(number>=100)
      number=number-100;
      hundred++;
    else
      break;
  while(1)
    if(number>=10)
      number=number-10;
      ten++;
    else
      break;
  number_txt[0]=hundred+'0';
  number_txt[1]=ten+'0';
  number_txt[2]=number+'0';
  number_txt[3]=0x00;
: Edited by User
von T_T (Guest)
Why this construct with while(1)/if?
This is simpler:
  while (number >= 100)
    number = number-100;
    hundred++;
  while (number >= 10)
    number = number-10;
    ten++;
  number_txt[0] = hundred+'0';
  number_txt[1] = ten+'0';
  number_txt[2] = number+'0';
  number_txt[3] = 0;
or still shorter:
    number -= 100;
    hundred++;
    number -= 10;
    ten++;
  number_txt[3] = 0;
von John M. (215)
I am trying to read it to an LCD display, but I am getting random
character on the display...
von John M. (215)
When i number = 100, is the character i get on my LCD
11111
11010
11111
11111
11111
11111
11111
11111
von T_T (Guest)
And what characters are on your lcd if you write out the string "100"
direct?
von John M. (215)
when i write 100 the char.  ] and
1111
1110
1100
1111
1101
1111
1111
1110
and if I write "100", 100 appears on the LCD.
oh.. i might have found the solution.. is it possible to get beyond the
limitation of the size of number..
: Edited by User
