Forum: ARM programming with GCC/GNU tools Still missing crt0.o
Author: Salman Sheikh (Guest)
Hello,
I have had massive problems getting a compile chain working with a
debugger using open source GCC tools. So, I am trying again with
Yagarto.
I installed the yagarto-tools and yagarto-20121222.
Using the command line, examples from this site for a AT91SAM7X256
example compiles with no problem. When trying to add the eclipse, I get
this error:
How do I remove the crt0.o dependency. According to one thread on this
site, its no longer needed but I am not sure how to delete it from the
build so I don't get this error.
12:06:20 **** Incremental Build of configuration Debug for project
SAM7X256Test ****
make all
Building target: SAM7X256Test
Invoking: Cross GCC Linker
arm-none-eabi-gcc  -o "SAM7X256Test"  ./src/low_level_init.o
./src/main.o
c:/yagarto-20121222/bin/../lib/gcc/arm-none-eabi/4.7.2/../../../../arm-n
one-eabi/bin/ld.exe:  cannot find crt0.o: No such file or directory
collect2.exe: error: ld returned 1 exit status
make: *** [SAM7X256Test] Error 1
Author: Helge K. (helge_k25)
I had the same problem. All answers I get pointed to implementing the
crt0.o by myself.
Since I am not a CRT implementer I switched to a working environment:
www.emide.org. Probably a path you may follow.
Author: W.S. (Guest)
It is so easy..
You are working with ARM/Cortex? yes? Of course you MUST provide a
startup code for your particular controller. It is necessary. Write one
by yourself or find 'away' one somewhere - hoping that it fit's to your
application. My hint is to download the "Lernbetty" here
(Beitrag "Die Lernbetty: Die SwissBetty von Pollin als ARM-Evalboard") and look for the
startupcode. This is for a ARM7TDMI architecture, a Cortex needs a
modified startup, but since the Lernbetty has a easy to understand batch
file for the whole compilation, you can easily adapt it for your
purposes.
W.S.
Author: Divergence (Guest)
I had the same problem wit trying to compile for STM32F4xx (Cortex M4).
I ditched Yagarto and switched to using GNU Tools ARM Embedded -
toolchain (4.8_2014q2):
https://launchpad.net/gcc-arm-embedded
Seems to work for me.
