Forum: FPGA, VHDL & Verilog step time simulation
von angelo (Guest)
Hi all,
I'm stuck on a simple issue but can't get out of it: I would like to
generate severals waveform signals for my future testbench but the
frequency of my signals are not correct.
Below is the code I want to simulate:
library ieee;
use ieee.std_logic_1164 .all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
use ieee.math_real.all;
entity triangle_generator is
 generic(AMP: real;
  OFFSET: real;
  FREQ: real;
  PHASE :real);
 port(wave1: out real);
end triangle_generator;
architecture archi of triangle_generator is
signal tmp1 : real := 0.0;
begin
 P1:process
 constant delta   : real := 1000.0e-12;
 constant fin  : time := 1000 ps;
30
 variable angle   : real := 0.0;
31
 variable t    : real := 0.0;
32
 variable PHASE_RAD : real := 0.0;
33
34
 begin
35
36
   PHASE_RAD := (math_2_pi * PHASE)/360.0;
37
38
  loop
39
   angle   := math_2_pi * FREQ * t;
40
   t := t + delta;
41
42
   tmp1 <= OFFSET+(AMP/2.0)*(2.0/math_pi)*arcsin(sin(angle));
43
44
   wait for fin;
45
46
  end loop;
47
48
  wait;
49
50
 end process P1;
51
52
 wave1 <= tmp1;
53
54
end archi;
When I simule this code with FREQ=100 000 000 Hz I get the waveform in
attachment, not really what I wanted. So I was thinking, if I write
delta = 1000.0e-15 maybe it will be right, but absolutly not. When I
change the value of delta, the frequency of the waveform is wrong.
So can you help me to get through this please?
angelo wrote:
> When I change the value of delta, the frequency of the waveform is
> wrong.
You are turning the wrong screw...
Think about this:
     wait for fin;
What is the cycle time of 100MHz?
How many 1ns steps will fit in 10ns?
Do you find any coincidence with your screenshot?
: Edited by Moderator
von angelo (Guest)
Hi! Thanks! Your advices help me a lot.
