Forum: FPGA, VHDL & Verilog Vmax not reached
von angelo (Guest)
Hi everyone,
I'm writing a code for a triangular wave generator in vhdl, and I have a
little issue. I want a signal with Vmax =3.3V and I never reach this
value, the max is 3.2999...
There is not a really big difference but may will be damaging for what I
want to simulate with this signal (14 bits ADC).
Do you have any hint to get exactly the 3.3 value, if is it possible?
Thank you!
My code is below:
library ieee;
use ieee.std_logic_1164 .all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
use ieee.math_real.all;
entity test is
  generic(AMP: real;
    OFFSET: real;
    FREQ: real);
  port(triangle: out real);
end test;
architecture archi of test is
signal tmp : real := 0.0;
begin
  P1:process
  constant delta   : real := 1000.0e-12;
  constant fin   : time := 1000 ps;
  variable t   : real := 0.0;
  variable Vmax    : real := AMP/2.0;
30
31
  begin
32
33
    loop
34
35
      t := t + delta;
36
      tmp <= OFFSET+Vmax*(2.0/math_pi)*arcsin(sin(math_2_pi*FREQ*t));
37
      wait for fin;
38
39
    end loop;
40
41
    wait;
42
43
  end process P1;
44
45
  triangle <= tmp;
46
47
end archi;
von Duke Scarring (Guest)
Do you want to synthesize the code for a FPGA or just simulating?
Duke
von angelo (Guest)
Hi!
Just simulating
angelo wrote:
> I never reach this value, the max is 3.2999
3.2999 is the same as 3.30 but its not expressible with binary digits.
It's the same as 0.5 in binary, a periodic fraction.
Duke
