Forum: µC & Digital Electronics Please help me with checking of the busy flag of a lcd in 4bit mode
von Aakash D. (aakashjsr)
I am able to execute commands on my lcd when I use delay instead of
checking the busy flag but when I check the busy flag,it appears as if
an infinite loop has started.Here's the connections for my 4 bit Lcd
with the AVR Atmega 16.Thanks a lot in advance :)
PB0-> RS ; PB1->ENABLE ; PB2->R/W ; PB3->NOT CONNECTED
PB4-PB7----->DB4-DB7
*************************** Code:
#define data PORTB
#define e PB1
#define rs PB0
#define rw PB2
void lcd_ready() //checks for busy flag
DDRB&=0b00001111; //data lines as read
int flag=0;
cbi(PORTB,rs);
sbi(PORTB,rw);
do
pos_pulse();
_delay_us(10);
flag=PINB;
flag=(flag&0x80); //to store the value of busy flag
pos_pulse(); //discard lower nibble
_delay_us(10);
}while(flag);
DDRB=0xff; //resetting data lines as output
void pos_pulse()
cbi(PORTB,e); // eable=0
_delay_us(2);
sbi(PORTB,e) ; // eable=1
_delay_us(2);
void neg_pulse()
sbi(PORTB,e); // eable=1
_delay_us(2);
cbi(PORTB,e) ; // eable=0
_delay_us(2);
void command(int a) // to receive and send command to LCD
//higher nibble
lcd_ready();
data=(a&0xf0);
cbi(PORTB,rs);
cbi(PORTB,rw);
neg_pulse();
//Lower Nibble
lcd_ready();
data=((a<<4)&0xf0);
cbi(PORTB,rs);
cbi(PORTB,rw);
neg_pulse();
void value(int a) //To send Data to the Lcd
//higher nibble
lcd_ready();
data=(a&0xf0);
sbi(PORTB,rs);
cbi(PORTB,rw);
neg_pulse();
//Lower Nibble
lcd_ready();
data=((a<<4)&0xf0);
sbi(PORTB,rs);
cbi(PORTB,rw);
neg_pulse();
von zufaulzumlogin (Guest)
I think theres something wrong. The second call of pos_pulse, shouldn>t
it be neg_pulse? And why is ist commented with ¨discard lower nibble?
> do
> pos_pulse();
> _delay_us(10);
> flag=PINB;
> _delay_us(10);
Thanks for the Reply.
The 2nd pulse is also +ve because I have read that the Lcd's read
operations are +ve edge trigerred where as its write operations are -ve
edge trigerred.
Since the Lcd is working in the 4 bit mode , the 1st pulse gives us the
upper nibble of the register which contains the busy flag and the 2nd
pulse gives us the value of lower nibble which doesn't has the busy flag
and so its discarded.
Please tell me if I am correct.
Thanks,
