Forum: FPGA, VHDL & Verilog fixed point precision
von Abdallah  . (Company: Home) (my_name)
Peace!
I want ask about the number of bits shoud I use in an fixed_point number
to obtein the good precision, precision of distance eclidean.
some detail:
I want to determine an vector of foor element VECT[MOY1,MOY2,MOY3,MOY4],
each element is the moyen of one quart of matrix of (64*64), the matrix'
element value varies (0-255)'''it's pixel valor'''
--> the result of division (MOY1=SUM/Nbits) has 8 bits in the integer
part;
Question: how many bits of fractional part shout I use to get the good
result (result of euclidean distance between two vector
VECT1[MOY11,MOY12,MOY13,MOY14] and VECT[MOY21,MOY22,MOY23,MOY24])..
thank you....peace:
von Duke Scarring (Guest)
You have to define the precision. Independed if you use fixed point or
integer number format.
The number of bits depends on your dynamic range:
http://en.wikipedia.org/wiki/Dynamic_range
Roughly: NoBs = SNR / 6
eg.: 16 Bit = 96 dB / 6
Duke
von Michael W. (Guest)
Why would you consider to be the DR at 16 Bits not to be 96dB but
96dB/6?
von ... (Guest)
You wanted a GOOD precission in the result, right? then divide it by 6
> 96dB/6?
Read carefully:
 number of bits * 6 dB = dynamic range
