Forum: FPGA, VHDL & Verilog for loop with real
von angelo (Guest)
Hi everyone!
I would like to create a for loop for code like this:
if input >= 1.0 then output = 11111111111111
if input =0.999878 then output = 11111111111110
if input =0.999756 then output = 11111111111101
if input = -0.999878 then output = 10000000000001
if input <= -1.0 then output = 10000000000000
It seams to be simple but apparently the paramater of the for loop can't
be of real type. Do you know an other way to do the same thing I want
but real compatible please ??
angelo wrote:
> Do you know an other way to do the same thing I want but real compatible
> please ??
Is this for simulation only or must it be implemented on real hardware?
BTW: when I look at your code then I am fairly sure that there is a kind
of algorithm or a formula to calculate the result...
von Tom (Guest)
For-loops with real/float types are allowed, but not always useful.
In this case I would use a linear function with no loop at all.
Something like "output = (input+1)*8192". Try it for a few input values.
von angelo (Guest)
Yes is this for simulation, I know real is not synthesizable.
Tom, few adaptations your code and that gives me exactly I want, thank
you a lot!
