Forum: ARM programming with GCC/GNU tools Help needed compiling source code ARM7
von IonutZ (Guest)
Hello,
I am new in this domain so please excuse my lack of knowledge about the
subject.
I have found an interesting subject about an ARM7 based OLED CLOCK and I
am trying to make it as my first project but I encountered some trouble
in compiling the source code.
I have made the PCB and now I am in the difficulty of compiling the
binary for uploading on the uC.
As far as I know the source code was made in the assembler language by
the developer and was compiled under Linux using the GNU toolkit
(compiler, linker, assembler, make) and openocd.
I have tried to make it work but I am not that skilled in using programs
in Linux using command lines and using other programs such as Atmel
Studio or Eclipse didn't help either.
So I have decided to ask here if there is someone willing to help me to
finish making my first project so I can understand at least at the basic
level how the compiling and debugging works.
Can someone please help me with the compiling of the source code to
obtain the binary so I can upload it on the uC?
The programmer I have is an olimex tiny h programmer and the developer
used a digilent jtag 3 but I don't think that is a big problem because I
need to have a binary file first... and maybe I will buy that programmer
also so it will work without modifying the code.
I have added an archive with all the documentation provided by the
developer. BTW, I have tried to contact the developer but no response
(maybe he changed his email in the last passing years).
Thank you in advance for any kind of help !
von Lyon (Guest)
Maybe it is wise to start up with smaller projects first, and read more
about tools available and use (nobody is born with knowledge, all
experienced that) - see this page:
http://www.atmel.com/devices/SAM7S64.aspx?tab=documents
and read the documents related to startup and GNU tools settings and use
(at least three documents mandatory…).
Lyon
von Marc P. (marcvonwindscooting)
I gave it a try, no success after 1/2 hour.
This is really a botch job! Every single step fails.
When trying to convert the *.jpg (s) into work/*.armasm and that failed,
too, I gave up.
What I did:
use my arm-none-eabi-gcc instead of the arm-..-gcc and other tools
(makefile).
Copy your jpegs to contrib and remove ' (1)' from the file names.
: Edited by User
von Lyon (Guest)
Now it is a bit more clear what you want. I did downloaded your package,
but seems to be something weird inside, my computer got blue screen when
opened your package.
You may use Gimp tool to:
i) adjust your jpegs to the size, color attributes needed for your
display;
ii)generate *.c language file corresponding to the jpeg (it is in the
format of an array of 0xYYZZ, ready to be compiled).
Another observation: it is your choice of coarse, but these days the
hot micro to use is a Cortex-Mx, many improvements over old ARM7TDMI
like yours, many other sites/brands offer good support to problems.
(Other brands offer special tools for such operation).
L
von Lyon (Guest)
Not seen from the beginning the name of the second poster - so mixed the
response. But really to convert jpeg to c code, use Gimp.
L
