Forum: FPGA, VHDL & Verilog VHDL Button Debouncing
Author: Matt (Guest)
Hello all,
I am currently writing a program to debounce a push button input. The
circuit(vhdl code) should debounce the buttons input after 20ms. The
problem I am facing, is the clock that i have to use is operating at
5MHZ which will debounce the button in a matter of microseconds if using
the tradition flip-flop debouncing technique. How can I obtain a clean
output after the button has been pushed for 20ms? Thanks!
Author: flip flopper (Guest)
you will have to use a counter to create the 20ms tick and use it as an
enable for the sampling FF.
the counter will be set to start with the very first button move
This sounds like a good method, however, I do not implement this in
vhdl. Do you have time to give me a quick example, or method in psuedo
code? Thanks
Author: 132 (Guest)
> vhdl.
Why do you the ask for VHDL code?
> code? Thanks
Take google.com, type vhdl debounce and find about 9000 hits.
http://www.deathbylogic.com/2011/03/vhdl-debounce/
http://zawiki.praxis-arbor.ch/doku.php/tschinz:vhd...
http://eewiki.net/pages/viewpage.action?pageId=4980758
1 useful
Lets take the first one:
  process (CLK, x)
    variable SDC : integer;
    constant Delay : integer := 50000;
  begin
    if CLK'Event and CLK = '1' then
This looks like beginner style because x is not necessary in the
sensitivity list and is not a really good style to use variables in such
an extensive manner.
Additionally it is not good to load a couter with a given value and
count it down to 0 afterwards:
          SDC := Delay;
          State <= S1;
        when S1 =>
          SDC := SDC - 1;
          if SDC = 0 then
            State <= S0;
This probably needs more ressources, because the reset inputs of a
flipflop inside the FPGA cannot be used for loading the counter. The
better way is to reset a counter and compare it with the uppermost
value.
The third link is the best code, but it uses the old obsolete
std_logic_unsigned lib. And to size the counter is far to difficult. Of
course it is/seems very efficient to size the counter a way that the
overflow of it can be used to trigger the sampling event, but in real
life it is much easier and straight away just to spend a little bit
logic and let the synthesizer do the timing calculations...
Matt wrote:
> How can I obtain a clean output after the button has been pushed for
> 20ms? Thanks!
Implement a counter counting up to 20ms.
Reset this counter whenever you detect a change in the input signal.
Sample the input the counter reaches 20ms.
Done.
Now lets take the code from the last link and transform it to a kind of
"up-to-date" style using the fancy new numeric_std lib instead of the
old synopsis libs:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
ENTITY debounce IS
  PORT( clk     : IN  STD_LOGIC;  --input clock
        button  : IN  STD_LOGIC;  --input signal to be debounced
        result  : OUT STD_LOGIC); --debounced signal
END debounce;
ARCHITECTURE behave OF debounce IS
  SIGNAL   inff    : STD_LOGIC_VECTOR(1 DOWNTO 0); -- input flip flops
  CONSTANT cnt_max : INTEGER := (33000000/50)-1 :  -- 33MHz and 1/20ms=50Hz
  SIGNAL   count   : INTEGER range 0 to cnt_max := 0;
BEGIN
  PROCESS(clk)
  BEGIN
    IF(clk'EVENT and clk = '1') THEN
      inff <= inff(0) & button;  -- sync in the input
      IF(inff(0)/=inff(1)) THEN  -- reset counter because input is changing
        count <= 0;
      ELSIF(count<cnt_max) THEN  -- stable input time is not yet met
        count <= count + 1;
      ELSE                       -- stable input time is met
        result <= inff(1);
      END IF;
    END IF;
  END PROCESS;
END behave;
> Thanks!
Youre welcome!
: Edited by Moderator
I looked over this code and it looks good. I tryed to run it and got a
few errors I cannot seem to get rid of. The error in question is on the
2nd if statement. Could you please check this out for me if you have
time? Thanks
Author: guest (Guest)
try /= instead of !=
But that was probably a test from Lothar ;)
Also note to write the exact error message next time, it was a easy one
here though...
Author: Matt Smith (mauromj)
I did not even notice that! I have been so used to C and assembly I have
lost most of my vhdl know how. I appreciate the help guys!
Thx, I changed the code according to your hint. Just as a try to excuse
that excessive bug: I'm doing a little bit C at the moment...
For sure it was! ;-)
Author: hoffbegone (Guest)
Would have been nice if this solution actually worked. Spent all day on
it till I finally figured out the race condition. Whew!
hoffbegone wrote:
> Spent all day on it till I finally figured out the race condition.
Glad to hear that you solved a problem. And now you simply keep your
little secret? You copy something from somewhere, but if there's a
problem and YOU solved it, then you keep it for yourself? Whow! Thumbs
up!
I can't see no "traditional" race condition up to now...
What particular problem did you have in what case?
And how did you solve it?
Author: Zuschauer (Guest)
I'm curious as well. Sounds like an unconstrained design.
Sorry for my erroneous post. My evaluation demonstrated a race condition
but then I found I made a coding error.
In addition, there is one syntax mistake:
ELSIF(cnt<cnt_max) THEN    -- stable input time is not yet met
should be
I demonstrated this routine worked as promised and verified it to my
satisfaction. Even my boss says this is a more "elegant" solution than
what he has used in the past.
BTW, I am a beginner and not an expert. Don't know what "unconstrained
design" means.
> should be
Thx for the response. I'll correct that.
> Don't know what "unconstrained design" means.
When you assign a output or input pin, thats a constraint. When you tell
the toochain to achieve at least 50MHz clock frequency (because your
crystal oscillator has that frequency) thats a constraint also.
> My evaluation demonstrated a race condition but then I found I made a
> coding error
Lets try a few guesses: usually thats due to a unsych'ed input signal.
Or it was a async reset generated out of combinatoric logic. Or it was a
simple combinatorial loop.
With those 3 guesses I will get the actual problem in 99% of the cases.
Just noticed the two posters after my initial post. I was very
frustrated and did not feel up to elaborating on my solution. Sorry.
But am glad I came back to correct my initial post.
I also neglected to say THANK YOU for this article. I learned a lot,
especially from my mistakes.
Oh, Lothar wants to know what mistake I made.
OK, here it goes. As I copied the code I made changes to the variables
to fit my design. When I came to:
result <= inff(1);
I thought, wait! inff(1) is the same as button and I typed in button
instead.
Code seemed to work until I increased the 20ms delay to 2 seconds so I
could actually see the delay (I was using a visible LED rather than a
scope). What I saw was the button was detected immediately on one edge
but then ignored, because of the delay, on the other edge. I was
expecting to see a delay on both edges. Must be a "race" condition. I
then modified the code and came up with my own similar solution.
It was my boss trying to understand your code when he said something
under his breath that caused me to realize the mistake I made.
I hope this explanation was entertaining.
> instead.
An async input into a FSM. The first of my guesses...;-)
> instead.
Indeed (you know it now) there are 2 flipflops between them.
Try that with Google translator, that is what you get with no sync
stages:
http://www.lothar-miller.de/s9y/archives/64-State-...
Author: Farnaz Amini (Company: student) (fa77)
Hi
I tried to use this code for debouncer but I have soe problem with this
line:
is it true?
could you please explain me
Thats no "debouncer" its simply a synching stage to bring the async
input to the FPGA clock domain.
What you have posted is just a concatenation (that's the & operator). If
you add a clock to this, then it will become a shift register.
  • [vhdl]VHDL code[/vhdl]
