Forum: FPGA, VHDL & Verilog find the max value between a given inputs
Author: tamara (Guest)
hi all
i need a vhdl code to find the max value from integer input where i have
a four input ??
thanks a lot
> a four input ??
Did you read your question? Do you understand it?
What do you have as input?
What do you want as output?
(this two questions can easily be answered with a entity declaration)
And what should happen in between?
And then for those thinking one step further:
Is it just for simulation?
Or must the result be synthesizeable for/on hardware?
If so: what data rates do you have to achieve?
You see: I have 8 questions to you. Please answer them. Then maybe we
can find a solution for your problem...
: Edited by Moderator
Lothar Miller wrote:
>> a four input ??
i have a 4 inputs every input has only one value such as
a => 100
b => 200
c => 300
d => 400
i want to find max between a,b,c,d should find d <= 400
> i think it some thing like comparator
yes
> Or must the result be synthesize-able for/on hardware?
is it difficult to be implemented
forgive me if i not clear my question in the beginning
and if i write and think aout not logic problem,you are our vhdl teacher
and we definitely learn from you
thanks a lot
  • [vhdl]VHDL code[/vhdl]
