Forum: FPGA, VHDL & Verilog what can i do?
Author: tanko (Guest)
hi every one....
i have a design measure the distance between two samples (inputs),
d(s1,s2). and i want to ask a question
if i have 4 samples such as [ s1,s2,s3,s4 ] and i want to get the
distances between every two samples, then i would have
d(s1,s2),d(s1,s3),d(s1,s4),d(s2,s3),d(s2,s4)and d(s3,s4).
what should i do 1 or 2
1- should i repeat that module 6 times and i would have 6 component of
it connected together to get the 6 distances between every sample and
the other ...or
2- should i use that module one time and store the distance in register
and reset the module then measure the distance between the next two
samples and store the the result in another register again and so on....
 because i will need the distances result for sum them all.
thanks for help.
Author: PittyJ (Guest)
Do 1
In this case the distance must be
dtot = 3 x d(s1,s4) + d(s2,s3)
because
d(s1,s4) = d(s1,s2) + d(s2,s4) = d(s1,s3) + d(s3,s4)
and therefore
dtot = d(s1,s4) + d(s1,s2)+d(s2,s4) + d(s1,s3)+d(s3,s4) + d(s2,s3)
> because
> and therefore
sorry i didn't get your remark well
the four samples s1,s2,s3,s4
different and the distances results would e different
If the distances are in ascending od descending order from s1 to s4 then
my suggestion will work. Otherwise it will be more complcated...
> If the distances are in ascending or descending order from s1 to s4 then
> my suggestion will work. Otherwise it will be more complicated...
no lother distances would not e ascending or descending order it will e
completely different ,so would you suggest to do 1 or 2 as pittyj
Take solution 1 if you have enough ressources on the FPGA.
  • [vhdl]VHDL code[/vhdl]
