Forum: FPGA, VHDL & Verilog Hot FPGA REASONS
Author: Rashmi Imhsar (Company: student) (rashmi)
I am using Cyclone III FPGA Starter kit which uses EP3C25F324 FPGA.
As soon as I power on my board, it is getting heated up rapidly in about
3 seconds. I am not even able to touch the FPGA , its that hot.
Does the FPGA usually get heated up rapidly when powered ON and then
cool down or does this mean there is some problem with the FPGA?
I fear to use the board for more than 5 Seconds as I fear it will spoil
the board.
Will using an external fan for cooling the FPGA help?
Author: cool fpga progger (Guest)
no, this is not normal.
during configuration, current gets high but temp will stay low though
such a high temp is mostly caused by a short cut of FPGA outputs, or
floating logic and outputs because of bad powering caused by a faulty
regulator
you should check the voltages
  • [vhdl]VHDL code[/vhdl]
