Forum: µC & Digital Electronics Old diskets to be used as rotary encoder
Author: Christian (Guest)
To many not any more needed disketts are lying around.
Did anybody try to use a special formated diskett as a rotary-encoder.
It should be possible to "save" some very fine and special pattern in
one or more parallel traces and use it after as a rotary encoder wheel.
To get the A/B info back down, reading heads from discdrives should be
working!?
I think that one could reach high resolution in diy-way.
Christian wrote:
> reading heads from discdrives should be working!?
A magentic disc is not a static system. You will need a significant
speed of the disc to induct enough voltage into the heads coil. So
stopping and turning the direction will cause tricky problems...
If the magnetic system does not work cd's could be used (is optical)!
Christian
Indeed, but you will have to implement a highly sopisticated controller.
and due to the usually very bad disc quality (most of the job in DVD and
CD is done by error correction) the whole system will not be
reproduceable and each encoder will be a prototype...
Author: JoergL (Guest)
Its much easier to use the encoder in an old mechanical mouse.
Has two of them (x and y axis)
Author: Andy D. (rackandboneman)
IIRC people used stepper motors for such purposes in the past... of
course, this will not yield absolute position.
For an optical encoder, a 600 dpi laser printer will likely be capable
of printing an encoder wheel on plastic film which will yield a rather
high resolution when assuming the encoder wheel can be multiple inches
in diameter.
The theoretical angular resolutions of floppy media (>10000bpi) seem
favourable, but there are probably good reasons (mechanical stability I
think) that only at most a few hundred tracks per inch were realized in
floppy disk systems.
A hard drive(!) platter and bearing would probably give you the
mechanical stability required. However, the way hard drive heads work
will turn into a huge problem with varying rotational speeds and
directions. IF what you want to do is get the exact current position of
a constantly spinning shaft this might work though - in the past, hard
drives used to do exactly that "for their own use" with a one side of a
platter dedicated to this task.
Thanks to all, I learned a lot!
Chistian
