Forum: FPGA, VHDL & Verilog to find error in vhdl code
Author: Anchal Agarwal (anchalagarwal)
This is a code and simulated waveform  of booth multiplier when we
simulated it on xilinx9.2i,
the syntex is cheked but on generating the waveform we are not getting
the correct output instead of multiplication, waveform shows the
previous value of input.
please check the code and reply the correct code on my email
id-anchalagarwal92@gmail.com
I will not open any *doc file. It may include some kind of malware. Best
would be to attach the *.vhd files and some screenshots as *.png or
*.gif...
I have send the .vhd and .png file  of code. please check it.
See the error message? Do you understand the error message? Whats the
value of uninitialized std_logic_vectors?
Try to initialize your signals like that:
signal sum, dif: std_logic_vector(mc'RANGE) := (others=>'0');
BTW: forget about that old obsolete libs
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
and the stupid calculating with vectors.
Take the
use IEEE.NUMERIC_STD.ALL;
instead!!!
Author: surbhi prakash (Guest)
please find the error in my code
Author: mhm (Guest)
We will not find the "error" in your code.
However some improvements in your question could change this:
1. give at least a small explanation of what the code shall do! You want
our help, so give some information first.
2. start an own thread for your problem, this one is over one year old!
(and I assume from your name, that you are not the original author)
3. don't give your code as .prj-file. I assume from the file name that
your code is written in VHDL so use the VHDL-type file ending (.vhd or
.vhdl) for proper syntax highlighting!
Thanks.
What "code"? There's only a 57-byte file with extension *.prj. I'm very
sure that thats no kind of "code".
Pls start a NEW thread, when you have a NEW question.
And there you can describe WHAT the "code" is expected to do. And WHAT
ist actually does instead. And HOW you did find that out. And if there
are any errors reported from your toolcahin you can write WHAT errrors
from WHAT part of WHAT toolchain.
And before sending your post you can read it as if you were somwhere on
the other half of the earth and you don't know anything about your
problem. And if you find, there's enough information, then you may press
the "SUBMIT" button.
Author: nerved (Guest)
The Error is located in Layer 8.
  • [vhdl]VHDL code[/vhdl]
