Forum: FPGA, VHDL & Verilog custom processor on FPGA
Author: Lovish Jain (Company: ITMU) (lovishjain)
-- Copyright (C) 2009, 2010 Dr. Juergen Sauermann
-- This code is free software: you can redistribute it and/or modify
-- it under the terms of the GNU General Public License as published by
-- the Free Software Foundation, either version 3 of the License, or
-- (at your option) any later version.
-- This code is distributed in the hope that it will be useful,
-- but WITHOUT ANY WARRANTY; without even the implied warranty of
-- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-- GNU General Public License for more details.
-- You should have received a copy of the GNU General Public License
-- along with this code (see the file named COPYING).
-- If not, see http://www.gnu.org/licenses/.
-- Module Name: io - Behavioral
-- Create Date: 13:59:36 11/07/2009
-- Description: the I/O of a CPU (uart and general purpose I/O lines).
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity io is
port ( I_CLK : in std_logic ;
I_CLR : in std_logic;
I_ADR_IO : in std_logic_vector( 7 downto 0);
I_DIN : in std_logic_vector( 7 downto 0);
I_SWITCH : in std_logic_vector( 7 downto 0);
I_RD_IO : in std_logic;
I_RX : in std_logic;
I_WE_IO : in std_logic;
Q_7_SEGMENT : out std_logic_vector( 6 downto 0);
Q_DOUT : out std_logic_vector( 7 downto 0);
Q_INTVEC : out std_logic_vector( 5 downto 0);
Q_LEDS : out std_logic_vector( 1 downto 0);
Q_TX : out std_logic);
end io;
architecture Behavioral of io is
component uart
generic(CLOCK_FREQ : std_logic_vector(31 downto 0);
BAUD_RATE : std_logic_vector(27 downto 0));
port( I_CLK : in std_logic;
I_RD : in std_logic;
I_WE : in std_logic;
I_TX_DATA : in std_logic_vector(7 downto 0);
Q_RX_DATA : out std_logic_vector(7 downto 0);
Q_RX_READY : out std_logic;
Q_TX : out std_logic;
Q_TX_BUSY : out std_logic);
end component;
signal U_RX_READY : std_logic;
signal U_TX_BUSY : std_logic;
signal U_RX_DATA : std_logic_vector( 7 downto 0);
signal L_INTVEC : std_logic_vector( 5 downto 0);
signal L_LEDS : std_logic;
signal L_RD_UART : std_logic;
signal L_RX_INT_ENABLED : std_logic;
signal L_TX_INT_ENABLED : std_logic;
signal L_WE_UART : std_logic;
begin
urt: uart
generic map(CLOCK_FREQ => std_logic_vector(conv_unsigned(25000000, 32)),
BAUD_RATE => std_logic_vector(conv_unsigned( 38400, 28)))
port map( I_CLK => I_CLK,
I_CLR => I_CLR,
I_RD => L_RD_UART,
I_WE => L_WE_UART,
I_TX_DATA => I_DIN(7 downto 0),
I_RX => I_RX,
Q_TX => Q_TX,
Q_RX_DATA => U_RX_DATA,
Q_RX_READY => U_RX_READY,
Q_TX_BUSY => U_TX_BUSY);
-- IO read process
iord: process(I_ADR_IO, I_SWITCH,
U_RX_DATA, U_RX_READY, L_RX_INT_ENABLED,
U_TX_BUSY, L_TX_INT_ENABLED)
begin
-- addresses for mega8 device (use iom8.h or #define __AVR_ATmega8__).
case I_ADR_IO is
when X"2A" => Q_DOUT <= -- UCSRB:
L_RX_INT_ENABLED -- Rx complete int enabled.
& L_TX_INT_ENABLED -- Tx complete int enabled.
& L_TX_INT_ENABLED -- Tx empty int enabled.
& '1' -- Rx enabled
& '1' -- Tx enabled
& '0' -- 8 bits/char
& '0' -- Rx bit 8
& '0'; -- Tx bit 8
when X"2B" => Q_DOUT <= -- UCSRA:
U_RX_READY -- Rx complete
& not U_TX_BUSY -- Tx complete
& not U_TX_BUSY -- Tx ready
& '0' -- frame error
& '0' -- data overrun
& '0' -- parity error
& '0' -- double dpeed
& '0'; -- multiproc mode
when X"2C" => Q_DOUT <= U_RX_DATA; -- UDR
when X"40" => Q_DOUT <= -- UCSRC
'1' -- URSEL
& '0' -- asynchronous
& "00" -- no parity
& '1' -- two stop bits
& "11" -- 8 bits/char
& '0'; -- rising clock edge
when X"36" => Q_DOUT <= I_SWITCH; -- PINB
when others => Q_DOUT <= X"AA";
end case;
end process;
-- IO write process
iowr: process(I_CLK)
begin
if (rising_edge(I_CLK)) then
if (I_CLR = '1') then
L_RX_INT_ENABLED <= '0';
L_TX_INT_ENABLED <= '0';
elsif (I_WE_IO = '1') then
case I_ADR_IO is
when X"38" => Q_7_SEGMENT <= I_DIN(6 downto 0); -- PORTB
L_LEDS <= not L_LEDS;
when X"40" => -- handled by uart
when X"41" => -- handled by uart
when X"43" => L_RX_INT_ENABLED <= I_DIN(0);
L_TX_INT_ENABLED <= I_DIN(1);
when others =>
end case;
end if;
end if;
end process;
-- interrupt process
ioint: process(I_CLK)
begin
L_INTVEC <= "000000";
else
if (L_RX_INT_ENABLED and U_RX_READY) = '1' then
if (L_INTVEC(5) = '0') then -- no interrupt pending
L_INTVEC <= "101011"; -- _VECTOR(11)
end if;
elsif (L_TX_INT_ENABLED and not U_TX_BUSY) = '1' then
L_INTVEC <= "101100"; -- _VECTOR(12)
end if;
else -- no interrupt
end if;
end if;
end if;
end process;
L_WE_UART <= I_WE_IO when (I_ADR_IO = X"2C") else '0'; -- write UART UDR
L_RD_UART <= I_RD_IO when (I_ADR_IO = X"2C") else '0'; -- read UART UDR
Q_LEDS(1) <= L_LEDS;
Q_LEDS(0) <= not L_LEDS;
Q_INTVEC <= L_INTVEC;
end Behavioral;
the error which I am getting is
Started : "Synthesize - XST".
Running xst...
Command Line: xst -intstyle ise -ifn "C:/Users/Lovish/Desktop/MyProject/src/avr_fpga.xst" -ofn "C:/Users/Lovish/Desktop/MyProject/src/avr_fpga.syr"
Reading design: avr_fpga.prj
*                          HDL Compilation                              *
Compiling vhdl file "C:/Users/Lovish/Desktop/MyProject/src/common.vhd" in Library work.
Compiling vhdl file "C:/Users/Lovish/Desktop/MyProject/src/reg_16.vhd" in Library work.
Architecture behavioral of Entity reg_16 is up to date.
Compiling vhdl file "C:/Users/Lovish/Desktop/MyProject/src/status_reg.vhd" in Library work.
Architecture behavioral of Entity status_reg is up to date.
Compiling vhdl file "C:/Users/Lovish/Desktop/MyProject/src/prog_mem_content.vhd" in Library work.
Compiling vhdl file "C:/Users/Lovish/Desktop/MyProject/src/alu.vhd" in Library work.
Architecture behavioral of Entity alu is up to date.
Compiling vhdl file "C:/Users/Lovish/Desktop/MyProject/src/register_file.vhd" in Library work.
Architecture behavioral of Entity register_file is up to date.
Compiling vhdl file "C:/Users/Lovish/Desktop/MyProject/src/data_mem.vhd" in Library work.
Architecture behavioral of Entity data_mem is up to date.
Compiling vhdl file "C:/Users/Lovish/Desktop/MyProject/src/prog_mem.vhd" in Library work.
Architecture behavioral of Entity prog_mem is up to date.
Compiling vhdl file "C:/Users/Lovish/Desktop/MyProject/src/uart.vhd" in Library work.
Architecture behavioral of Entity uart is up to date.
Compiling vhdl file "C:/Users/Lovish/Desktop/MyProject/src/opc_fetch.vhd" in Library work.
Architecture behavioral of Entity opc_fetch is up to date.
Compiling vhdl file "C:/Users/Lovish/Desktop/MyProject/src/opc_deco.vhd" in Library work.
Architecture behavioral of Entity opc_deco is up to date.
Compiling vhdl file "C:/Users/Lovish/Desktop/MyProject/src/data_path.vhd" in Library work.
Architecture behavioral of Entity data_path is up to date.
Compiling vhdl file "C:/Users/Lovish/Desktop/MyProject/src/cpu_core.vhd" in Library work.
Architecture behavioral of Entity cpu_core is up to date.
Compiling vhdl file "C:/Users/Lovish/Desktop/MyProject/src/io.vhd" in Library work.
Entity <io> compiled.
Entity <io> (Architecture <behavioral>) compiled.
Compiling vhdl file "C:/Users/Lovish/Desktop/MyProject/src/segment7.vhd" in Library work.
Architecture behavioral of Entity segment7 is up to date.
Compiling vhdl file "C:/Users/Lovish/Desktop/MyProject/src/avr_fpga.vhd" in Library work.
Architecture behavioral of Entity avr_fpga is up to date.
*                     Design Hierarchy Analysis                         *
Analyzing hierarchy for entity <avr_fpga> in library <work> (architecture <behavioral>).
Analyzing hierarchy for entity <cpu_core> in library <work> (architecture <behavioral>).
Analyzing hierarchy for entity <io> in library <work> (architecture <behavioral>).
"C:/Users/Lovish/Desktop/MyProject/src/io.vhd" line 78: In entity <io>
ERROR:Xst:2585 - Port <I_CLK> of instance <urt> does not exist in definition <uart>. Please compare the definition of block <uart> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <I_CLR> of instance <urt> does not exist in definition <uart>. Please compare the definition of block <uart> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <I_RD> of instance <urt> does not exist in definition <uart>. Please compare the definition of block <uart> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <I_RX> of instance <urt> does not exist in definition <uart>. Please compare the definition of block <uart> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <I_TX_DATA> of instance <urt> does not exist in definition <uart>. Please compare the definition of block <uart> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <I_WE> of instance <urt> does not exist in definition <uart>. Please compare the definition of block <uart> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Q_RX_DATA> of instance <urt> does not exist in definition <uart>. Please compare the definition of block <uart> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Q_RX_READY> of instance <urt> does not exist in definition <uart>. Please compare the definition of block <uart> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Q_TX> of instance <urt> does not exist in definition <uart>. Please compare the definition of block <uart> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Q_TX_BUSY> of instance <urt> does not exist in definition <uart>. Please compare the definition of block <uart> to its component declaration to detect the mismatch.
entity <uart> with generics:
  BAUD_RATE: from generic/parameter on instance : array unsigned [27 downto 0] of bit := "0000000000001001011000000000"
  CLOCK_FREQ: from generic/parameter on instance : array unsigned [31 downto 0] of bit := "00000001011111010111100001000000"
Total memory usage is 257036 kilobytes
Number of errors   :   10 (   0 filtered)
Number of warnings :    0 (   0 filtered)
Number of infos    :    0 (   0 filtered)
Process "Synthesize - XST" failed
please help me out
: Edited by Moderator
Where is the definition of the compunent uart?
It may be there:
> Library work.
But who knows?
Does the definition of the entity uart match the component
declaration ind the code above?
  • [vhdl]VHDL code[/vhdl]
