Forum: FPGA, VHDL & Verilog design works on fpga, but in simulation a counter is always 'x'
von Jay C. (jay_c)
I have an ax8 from opencores that runs a counter that shows on the leds
on my development board. I'm very happy, it works.
I wanted to simulate this too, after all this is very educational. I
also wanted to change the program with a generated rom in block ram
afterwards.
I wrote a very simple text fixture in Verilog (the ax8 is in VHDL) to
run my simulation. Unfortunately the counter clk_div stays undefined all
the time, so the processor doesn't even get its clock to work.
I use Xilinx webpack 12.4 and ISim for this.
I attached the top-level module and the test-fixture code to this post.
What am I doing wrong?
Many thanks in advance.
Jay Christnach wrote:
> Unfortunately the counter clk_div stays undefined all the time
Give it an initial value:
signal clk_div : std_logic_vector(15 downto 0) := (others=>'0');
This may also apply to the other signals...
BTW: in my eyes this design is rubbish!
Never ever generate a clock like this:
      if clk_div > x"0018" then
        Clk <= '1';  -- A more symmetric clock.
      else
        Clk <= '0';
      end if;
The FPGA designer implemented clock managers to generate clocks.
von Jay C. (jay_c)
Hello Lothar,
Many thanks. This did help indeed. I'm impressed by the enormous
verbosity of VHDL. I still have to learn this, for now I'm still Verilog
only.
But how do I know if I have to set an initial value like this? In the
whole rest of the design I didn't have to change anything, but it all
worked.
I copied the top level from an experienced developer, the rest is the
ax8 from opencores. Maybe you want to explain what I would gain from a
DCM, but I guess I can look that up elsewhere. After all this works
independantly from the tools or hardware. It's maybe a quick and dirty
way to do it.
BTW, I also came across your website, which has a lot of information.
Thanks again!
Jay
> Many thanks.
You're welcome.
You can/should/must set ist for registered values (those being clocked)
if you don't have a explicit reset path in the process (which is
usuallay not necessary, see WP272 from Xilinx).
You just must know, that the simulator inititlizes signals/variables
implcitly with the leftmost value of the according type if you don't
explicitly assign your desired value. And the leftmost value for the
type std_logic is 'U'
(http://www.quicknet.se/hdc/hdl/educaton/types/exampl.htm) which results
together with something else to an 'X'.
The synthesizer is not able to do anything other than '1' and '0' inside
the FPGA (and also a 'Z' on the IO cells), and so it assigns a '0' to
uninitialized values.
Therefore often the rumor is: in real life it is ok, in simulation it
doesn't work! And thats only a hint that the simulation is simply wrong
due to an incomplete VHDL model.
In Verilog lots of those declarations are implicitly done and a little
bit more hidden from an occasional reader. VHDL is more straightforward,
you must explicitly write down such things and so it is more obvious
that/when they are missing.
: Edited by Moderator
