Forum: FPGA, VHDL & Verilog How to use Memory
von Abdallah  . (Company: Home) (my_name)
Hi, I need some help
I want to receive data on online to the FPGA Board, so I should use
memory as I know.
the problem is I haven't my own board, so I should prepare to apply the
code in the board in only one day, for that I need some guiding.
how can I put the data in RAM (is it from Interface), what acquaintances
should I have to go in coding with the min problem
thank you,greetings
What is "online"? Is it "from the Internet" via a protocol stack and an
ethernet interface? Or is it just via a simple serial (e.g. RS232)
interface in direct ordered binary format?
> to the FPGA Board
Which board? And which language?
> so I should prepare to apply the code in the board in only one day
This will not work unless you are very experiecend and unless you have a
very clear picture of your design.
That is not your actual problem. Just to tie up all of the loose ends
here and there in https://embdev.net/topic/326197 and in
https://embdev.net/topic/325291 :
If you don't clarify your task and offer all of the information you have
no one will be able to guide you the right way. And then "no guidance"
is better than "wrong guidance"...
ok, thnks
Abdallah      wrote:
> ok, thnks
You're welcome...  :-/
