Forum: FPGA, VHDL & Verilog writting code in vhdl
von basma (Guest)
hi all,,,
i want a code in vhdl to make this equation . like the the following
d(s1,s2)=(1+1+0+1+1)/(n^2/2)=4/12=0.33333 .
(1+1+0+1+1) is the distances between input data use the accumulator to
sum the distances.
n is the number of input data if even multiply n*n if odd n*n-1
then divide accumulator over the numbers of inputs if even or odd
i want a help please in how to make this vhdl code
von Duke Scarring (Guest)
1. Show us, what have you done so far.
2. Ask particular questions.
von basma (Guest)
ok
how i make it in vhdl code
library ieee;
use ieee.std_logic_1164.all;
library ieee;
entity test is
    port(
        rst      : in  std_logic;
        clk      : in  std_logic;
        we       : in  std_logic;
        wr_data1 : in  std_logic_vector(7 downto 0);
        wr_data2 : in  std_logic_vector(7 downto 0);
        wr_addr  : in  integer range 0 to 255;
       N_of_samp: out integer range 0 to 255;
        distance : out integer range 0 to 255;
      sum      : out integer range 0 to 255;
        vout     : out std_logic;
        no_match : out std_logic
end entity;
signal accum    : integer range 0 to 255 := 0;
signal dis      : integer range 0 to 255 := 0;
signal n        : integer range 0 to 255 := 0;
process (n,accum)
begin
if (n mod 2) /= 0 then
N_of_samp <= (n*n)-1;
else
N_of_samp <= (n*n);
30
end if;
31
32
end process;
33
end rtl;
i try to do it in a part of the code but it calculate n
like(1,2,3,....10)
and test it if even make n*n and if odd make n*n-1
and i want to use the result oonoly i.e i want t use the result of
conter 10 and test it then make division but it gave me result like the
picture attached.
i hope y understand me
: Edited by Moderator
Where does n came from?
In you code it is always zero.
The posted code does not match the screenshot.
Pls. add the tokens [ vhdl ] and [ /vhdl ] without the blanks around
your VHDL code. This will give you neat syntax highlighting...
von basma (Guest)
n came from a counter count the number of input samples
library ieee;
entity test is
    port(
        rst      : in  std_logic;
        clk      : in  std_logic;
        we       : in  std_logic;
      norm_distance:out integer range 0 to 255;
end entity;
architecture rtl of test is
signal rd_data1 : std_logic_vector(7 downto 0);
signal rd_data2 : std_logic_vector(7 downto 0);
signal rd_addr1 : integer range 0 to 255 := 0;
signal rd_addr2 : integer range 0 to 255 := 0;
signal norm_dis : integer range 0 to 255 := 0;
30
signal n_of_samples : integer range 0 to 255 := 0;
31
type states is (s0,s1,s2);
32
signal state: states;
33
34
component wr_rd_ram
35
    port(
36
        clk      : in  std_logic;
37
        we       : in  std_logic;
38
        wr_data  : in  std_logic_vector(7 downto 0);
39
40
        rd_addr  : in  integer range 0 to 255;
41
        rd_data  : out std_logic_vector(7 downto 0)
42
43
end component;
44
45
begin
46
47
ram1:entity work.wr_rd_ram
48
    port map(
49
        clk      => clk,
50
        we       => we,
51
        wr_data  => wr_data1,
52
        wr_addr  => wr_addr,
53
        rd_addr  => rd_addr1,
54
        rd_data  => rd_data1
55
56
57
ram2:entity work.wr_rd_ram
58
    port map(
59
        clk      => clk,
60
        we       => we,
61
        wr_data  => wr_data2,
62
        wr_addr  => wr_addr,
63
        rd_addr  => rd_addr2,
64
        rd_data  => rd_data2
65
66
process(rst,clk)
67
begin
68
if rst = '1' then
69
70
 rd_addr1 <= 0;
71
 rd_addr2 <= 0;
72
    accum <= 0;
73
   N     <= 0;
74
    state <= s0;
75
    vout <= '0';
76
    no_match <= '0';
77
    distance <= 0;
78
elsif rising_edge(clk) then
79
if we  = '0' then
80
   vout <= '0';
81
   no_match <= '0';
82
   state <= s2;
83
   case state is
84
      when s0 =>
85
        rd_addr2 <= rd_addr2 + 1;
86
        if rd_data2 = rd_data1 then
87
      N <= N + 1 ;
88
           state <= s1;
89
           dis <= abs (rd_addr1 - rd_addr2);
90
        accum <= accum + dis;
91
           vout <= '1';
92
        elsif rd_addr2 = 255 then
93
           rd_addr2 <= 0;
94
           state <= s2;
95
        end if;
96
97
      when s1 =>
98
        rd_addr1 <= rd_addr1 + 1;
99
100
        rd_addr2 <= 0;
101
        state <= s0;
102
103
      when s2 =>
104
         no_match <= '1';
105
      vout <= '0' ;
106
         state <= s0;
107
108
109
      when others => null;
110
111
   end case;
112
113
end if;
114
end if;
115
distance <= dis ;
116
sum <= accum ;
117
end process;
118
process (n,accum)
119
begin
120
121
N_of_samples <= (n*n)-1;
122
norm_dist <= dis / N_of_samples;
123
else
124
N_of_samples <= (n*n);
125
norm_dis <= dis / N_of_samples;
126
127
end if;
128
norm_distance <= norm_dis;
129
end process;
also it gave me error divide by zero
basma wrote:
> if rst = '1' then
>    N     <= 0;
> else
> end if;
Just start thinking: what will happen if if reset is asserted? What is
0*0?
BTW: add the [] around  vhdl  and  /vhdl
So it looks like [/vhdl] after the end and [vhdl] before the beginning
of the VHDL code.
After changing 'norm_dist' to 'norm_dis', and add a missing 'end
architecture', your code compile.
Did you have a testbench?
von basma (Guest)
sorry for missing it ,but also if i did it gave me error divid by zero
von basma (Guest)
> 0*0?
all i want i have a counter count the number of input sample i want to
fatch the result from this counter to test it ,because it gave me
values(0,1,2....100)i want to test if 100 is even oe odd and divide
distance on it. but how i can make it
