Forum: µC & Digital Electronics Problem with atmega -8
von Ajay R. (ajay_r)
Hey..I am trying my hands on lcd 16x2 and somehow i got it to work.I'm
trying to display an output on 16x2 which is dependent on sum input on
other pins but cant get it to work.Here is my code..
 #define F_CPU 1000000UL
#include <avr/io.h>
#include <util/delay.h>
#define LCD_DATA PORTB                //LCD data port
#define ctrl PORTD
#define en PD2                         // enable signal
#define rw PD1                       // read/write signal
#define rs PD0                     // register select signal
int main()
DDRB=0xff;                                  // setting the port B
DDRD=0x07;                                // setting for port D
DDRC=0;
PORTC=0b0000000;
init_LCD();                                 // initialization of LCD
_delay_ms(50);                        // delay of 50 mili seconds
LCD_write_string("“hello world”");                      // function to print string on LCD
if(PINC==0b0000001){
_delay_ms(50);
LCD_cmd(0xc0);
_delay_ms(1);
LCD_write_string("THIS IS WORKING ");}
return 0;
30
31
32
void init_LCD(void)
33
34
LCD_cmd(0x38);                            // initialization of 16X2 LCD in 8bit mode
35
_delay_ms(1);
36
LCD_cmd(0x01);                                 // clear LCD
37
_delay_ms(1);
38
LCD_cmd(0x0E);                        // cursor ON
39
_delay_ms(1);
40
LCD_cmd(0x80);                     // —8 go to first line and –0 is for 0th position
41
_delay_ms(1);
42
return;
43
44
45
void LCD_cmd(unsigned char cmd)
46
47
LCD_DATA=cmd;
48
ctrl =(0<<rs)|(0<<rw)|(1<<en);
49
_delay_ms(1);
50
ctrl =(0<<rs)|(0<<rw)|(0<<en);
51
_delay_ms(50);
52
return;
53
54
55
void LCD_write(unsigned char data)
56
57
LCD_DATA= data;
58
ctrl = (1<<rs)|(0<<rw)|(1<<en);
59
_delay_ms(1);
60
ctrl = (1<<rs)|(0<<rw)|(0<<en);
61
_delay_ms(50);
62
return ;
63
64
65
void LCD_write_string(unsigned char *str)             //store address value of the string in pointer *str
66
67
int i=0;
68
while(str[i]!='\0')                               // loop will go on till the NULL character in the string
69
70
LCD_write(str[i]);                            // sending data on LCD byte by byte
71
i++;
72
73
return;
74
The first line ie HELLO WORLD is working fine but there is no display in
the second line.
von Ralf (Guest)
> _delay_ms(50);
> LCD_cmd(0xc0);
> _delay_ms(1);
The program doesn't wait for PINC -> 1
Ralf wrote:
>> _delay_ms(50);
>> LCD_cmd(0xc0);
>> _delay_ms(1);
I didnt get can you elaborate a bit please.
von sepp1985 (Guest)
#include <avr/io.h>
#define ctrl PORTD
int main()
DDRC=0;
PORTC=0b0000001;  //Sink mode???
while(1) //do it ever and ever and ever
_delay_ms(50);
LCD_cmd(0xc0);
30
_delay_ms(1);
31
32
33
return 0;
34
35
36
void init_LCD(void)
37
38
39
_delay_ms(1);
40
41
_delay_ms(1);
42
43
_delay_ms(1);
44
45
_delay_ms(1);
46
return;
47
48
49
50
51
LCD_DATA=cmd;
52
53
_delay_ms(1);
54
55
_delay_ms(50);
56
return;
57
58
59
60
61
LCD_DATA= data;
62
63
_delay_ms(1);
64
65
_delay_ms(50);
66
return ;
67
68
69
70
71
int i=0;
72
73
74
75
i++;
76
77
return;
78
: Edited by Admin
von Route_66 (Guest)
What is connected to PORT C, especialli at bit 0 of it?
sorry, bit 1 of port C.
von B.A. (Guest)
This linie is possiply wrong.
You want to do something if PC0 (Pin0 from Port C) is high?
try this:
if(PINC & 0b0000001){
Route_66 wrote:
> sorry, bit 0 of port C.
just a constant voltage source. I was trying to test thats why
I tried this code and it worked fine for a simple led
 #include <avr/io.h>
int main(void) {
DDRB=0;
DDRC=0b11111111;
PORTC=0b00000000;
PORTB=0b00000000;
if(PINB==0b00000001)
{PORTC=0b11111111;}
return 0;
but when i interchanged PORTC AND PORTB ie interchanged their function
it didnt worked.So i guess there in something wrong with input pins at
PORTC.By the way im using proteus for simulating
von Ralf (Guest)
> _delay_ms(50);
> LCD_cmd(0xc0);
> _delay_ms(1);
thereabouts.
But what changes the bit? I think, you would better wait (e.g. if it is
a button)
von Ralf (Guest)
Sorry, to slow.
>> _delay_ms(50);
>> LCD_cmd(0xc0);
>> _delay_ms(1);
> thereabouts.
> a button)
I understand what you are saying but im not using a switch pinc is
connected to vcc from the beginning no switch is there
von B.A. (Guest)
PC0 = high
PC1 ... PC7 = low
Do you have connect the other Pins (Pin 1 to Pin 7) from Port C to
Ground?
> PC0 = high
> PC1 ... PC7 = low
> Ground?
Yes...Done that
TAKE A LOOK AT THIS
 #include <avr/io.h>
int main(void) {
DDRB=0;
DDRC=0b11111111;
PORTC=0b00000000;
PORTB=0b00000000;
{PORTC=0b11111111;}
return 0;
von B.A. (Guest)
>> Ground?
> Yes...Done that
Realy?
PC6 is the Reset-Pin of the ISP-Port ... this Pin must be high, if it is
Low the AVR is in Programming-Mode.
