Forum: FPGA, VHDL & Verilog How to increases Maximum operating freqency
von Vinayak S. (vinayak_s)
library ieee ;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity map1 is
  port(clk:in std_logic;
  reset:in std_logic;
  code_rate:in std_logic_vector(3 downto 0);
  mod_mode_sel:in std_logic_vector(1 downto 0);
  N_ldpc:in std_logic_vector(15 downto 0);
  input1:in std_logic;
  out_R:out std_logic_vector(15 downto 0);
  out_I:out std_logic_vector(15 downto 0));
end map1;
architecture arch of map1 is
subtype select_1_2 is integer;
type select_e is array (0 to 2, 0 to 63) of select_1_2;
constant e:select_e:= ((7,1,4,2,5,3,6,0, 7,1,4,2,5,3,6,0, 11,7,3,10,6,2,9,5,1,8,4,0, 11,7,3,10,6,2,9,5,1,8,4,0, 15,1,13,3,8,11,9,5,10,6,4,7,12,2,14,0, 7,3,1,5,2,6,4,0) , (0,5,1,2,4,7,3,6, 7,1,4,2,5,3,6,0, 2,7,6,9,0,3,1,8,4,11,5,10, 11,7,3,10,6,2,9,5,1,8,4,0, 2,11,3,4,0,9,1,8,10,13,7,14,6,15,5,12, 7,3,1,5,2,6,4,0) , (7,1,4,2,5,3,6,0, 7,1,4,2,5,3,6,0, 11,7,3,10,6,2,9,5,1,8,4,0, 11,7,3,10,6,2,9,5,1,8,4,0, 7,2,9,0,4,6,13,3,14,10,15,5,8,12,11,1,  7,3,1,5,2,6,4,0));
type select_16 is array (0 to 3) of std_logic_vector(15 downto 0);
signal Zq_16:select_16:= ("0011110010110111", "0001010000111101", "1011110010110111", "1001010000111101");
type select_64 is array (0 to 7) of std_logic_vector(15 downto 0);
constant Zq_64:select_64:= ("0100010100100000", "0011000101100000", "0000100111100000", "0011001101010000", "1100010100100000", "1011000101100000", "1000100111100000", "1011001101010000");
type select_256 is array (0 to 15) of std_logic_vector(15 downto 0);
30
constant Zq_256:select_256:= ("0100100110100000", "0011111111001111", "0010110000101101", "0011010111111110", "0000010011101000", "0000111010111001", "0010001001011100", "0001100010001010", "1100100110100000", "1011111111001111", "1010110000101101", "1011010111111110", "1000010011101000", "1000111010111001", "1010001001011100", "1001100010001010");
31
32
signal rate : integer range 0 to 4;
33
signal mod_sel : integer range 0 to 63;
34
signal SET : integer range 0 to 16;
35
signal b: std_logic_vector(31 downto 0);
36
signal count: integer range 0 to 33;
37
signal flag : std_logic;
38
39
begin
40
41
42
  flag <= '0' when reset = '1' else '1' when  count = SET+SET ;
43
44
  ---here "0001" is for code rate 3/5 , "0010" for code rate 2/3 and "0000" for all others....
45
46
  rate <= 0 when code_rate ="0000"  else 1 when code_rate = "0001" else 2 when code_rate = "0010" else 0 ;
47
48
  ---depending on the modulation format and N_ldpc value index going to change--------
49
  mod_sel <= 0  when (mod_mode_sel = "01" and N_ldpc="1111110100100000") else
50
             8  when (mod_mode_sel = "01" and N_ldpc="0011111101001000") else
51
             16 when (mod_mode_sel = "10" and N_ldpc="1111110100100000") else
52
             28 when (mod_mode_sel = "10" and N_ldpc="0011111101001000") else
53
             40 when (mod_mode_sel = "11" and N_ldpc="1111110100100000") else
54
             56 when (mod_mode_sel = "11" and N_ldpc="0011111101001000") ;
55
56
  ---- selecting number of substreams--------------
57
  SET <= 2  when mod_mode_sel = "00"  else
58
         8  when mod_mode_sel = "01"  else
59
         12 when mod_mode_sel = "10" else
60
         16 when (mod_mode_sel = "11" and N_ldpc="1111110100100000") else
61
         8  when (mod_mode_sel = "11" and N_ldpc="0011111101001000");
62
63
process(clk, reset)
64
  begin
65
    if reset = '1' then
66
      count <= 0;
67
68
    elsif rising_edge(clk) then
69
      if count = SET+SET then
70
        count <= 1;
71
      else
72
        count <= count + 1;
73
      end if;
74
    end if;
75
end process;
76
77
process(clk, reset , flag)
78
  variable i: integer ;
79
  variable j: integer ;
80
81
  begin
82
83
    if reset = '1' then
84
     b <= (others=>'0');
85
     i := 0;
86
     j := 0;
87
88
89
90
      if  (mod_mode_sel /= "00" and (count >= 1 and count <= SET+SET)) then
91
92
        b( e(rate , mod_sel+i) + j ) <= input1;
93
          i := i + 1 ;
94
95
96
            if i = SET then
97
              j :=  j + SET ;
98
              i := 0 ;
99
            end if;
100
101
            if j = SET+SET then
102
              j := 0 ;
103
            end if;
104
105
106
      end if;
107
  end if;
108
end process;
109
110
111
process (clk)
112
  variable sel_1: std_logic_vector(3 downto 0);
113
  variable sel_2: std_logic_vector(3 downto 0);
114
115
  begin
116
117
118
      ------Mapping for QPSK----------
119
120
      if mod_mode_sel = "00" and count >= 1 then
121
        if input1 = '0' then
122
          out_r <= "0101101010000010" ;
123
          out_i <= "0101101010000010" ;
124
        elsif input1 ='1' then
125
          out_r <= "1101101010000010" ;
126
          out_i <= "1101101010000010" ;
127
        end if;
128
      end if;
129
130
      -------Mapping for both 16-QAM ,64800/16200  and 256-QAM , 16200 ---------
131
     if mod_mode_sel = "01" or (mod_mode_sel = "11" and N_ldpc="0011111101001000") then
132
133
      if  count = 9 then
134
135
          sel_1 := "00" & b(0) & b(2) ;
136
          out_r <= Zq_16(to_integer(unsigned(sel_1)));
137
138
          sel_2 := "00" & b(1) & b(3) ;
139
          out_i <= Zq_16(to_integer(unsigned(sel_2)));
140
141
      end if;
142
143
      if  count = 13 then
144
145
          sel_1 := "00" & b(4) & b(6) ;
146
147
148
          sel_2 := "00" & b(5) & b(7) ;
149
150
      end if;
151
152
      if flag = '1' and  count = 1 then
153
154
          sel_1 := "00" & b(8) & b(10) ;
155
156
157
          sel_2 := "00" & b(9) & b(11) ;
158
159
      end if;
160
161
      if flag = '1' and  count = 5 then
162
163
          sel_1 := "00" & b(12) & b(14) ;
164
165
166
          sel_2 := "00" & b(13) & b(15) ;
167
168
      end if;
169
    end if;
170
171
    -------Mapping for 64-QAM and 64800/16200---------
172
173
    if mod_mode_sel = "10"   then
174
      if  count = 13 then
175
176
          sel_1 := '0' & b(0) & b(2) & b(4) ;
177
          out_r <= Zq_64(to_integer(unsigned(sel_1)));
178
179
          sel_2 := '0' & b(1) & b(3) & b(5) ;
180
          out_i <= Zq_64(to_integer(unsigned(sel_2)));
181
      end if;
182
183
      if  count = 19 then
184
185
          sel_1 := '0' & b(6) & b(8) & b(10) ;
186
187
188
          sel_2 := '0' & b(7) & b(9) & b(11) ;
189
190
      end if;
191
192
193
194
          sel_1 := '0' & b(12) & b(14) & b(16) ;
195
196
197
          sel_2 := '0' & b(13) & b(15) & b(17) ;
198
199
      end if;
200
201
      if flag = '1' and  count = 7 then
202
203
          sel_1 := '0' & b(18) & b(20) & b(22) ;
204
205
206
          sel_2 := '0' & b(19) & b(21) & b(23) ;
207
208
      end if;
209
210
 end if;
211
212
   -------Mapping for 256-QAM and 64800---------
213
214
   if (mod_mode_sel = "11" and N_ldpc="1111110100100000")  then
215
      if  count = 17 then
216
217
          sel_1 := b(0) & b(2) & b(4) & b(6) ;
218
          out_r <= Zq_256(to_integer(unsigned(sel_1)));
219
220
          sel_2 := b(1) & b(3) & b(5) & b(7) ;
221
          out_i <= Zq_256(to_integer(unsigned(sel_2)));
222
      end if;
223
224
      if  count = 25 then
225
226
          sel_1 := b(8) & b(10) & b(12) & b(14) ;
227
228
229
          sel_2 := b(9) & b(11) & b(13) & b(15) ;
230
231
      end if;
232
233
234
235
          sel_1 := b(16) & b(18) & b(20) & b(22) ;
236
237
238
          sel_2 := b(17) & b(19) & b(21) & b(23) ;
239
240
      end if;
241
242
      if flag = '1' and  count = 9 then
243
244
          sel_1 := b(24) & b(26) & b(28) & b(30) ;
245
246
247
          sel_2 := b(25) & b(27) & b(29) & b(31) ;
248
249
      end if;
250
251
 end if;
252
 end if;
253
254
  end process;
255
256
end arch;
when I synthesized its give 87MHz in Spartan 3A-DSP.
pls help me......
: Edited by Moderator
von Schlumpf (Guest)
google: "pipelining"
von Duke Scarring (Guest)
At first you should use [ vhdl ] and [ / vhdl ] to tag the code (use
tags without spaces).
Second, to enhance readability I would suggest
out_r <= std_lgoic_vector( to_unsigned( 23170, 16));
rather than
To define out_r as unsigned could further enhance clarity.
What speed did you need?
The 87 MHz, is then number from synthesis only or after place & route?
Duke
I did it and got a little magic: syntax highlighting.
Vinayak S. wrote:
Why this? A subtype is useful if you want to constrain the base type.
Somthing like this:
 subtype select_1_2 is integer range 0 to 12;
Do you know that this is a big monstermultiplexer. Maybe you can
implement this function with a RAM. That would be much faster...
Fine. And whats the problem with that? Which one is the critical path?
