Forum: µC & Digital Electronics Atmel Studio: how to change compiler output directory?
von Markus G. (grabner)
Hi!
I have two projects in one Atmel Studio 6.1 solution which share some
source files, but are compiled for different controller types. When one
project is compiled, the resulting object files are unusable for the
second project since the object files are stored at the same location
for both projects. This could easily be solved by specifying different
object file directories for the two projects.
In Visual Studio (which Atmel Studio is based on), one can freely choose
the output directory, but I couldn't find a similar option in Atmel
Studio. Does anybody know how this can be done in Atmel Studio (either
in the IDE or by some compiler options)?
Thanks & kind regards,
Markus
von Jacy Jung (Guest)
Oh, I faced this problem so often :)
I would recommend you creating one directory, call it eg. "project". In
this directory you create a subdirectory "universal" with files that are
independent from the controller type. In that "universal" directory you
have one entry file, for example "universal.c" which includes all
necessary headers and files.
Then, create a second subdirectory in the "project" directory, call it
eg. "ATMega8". In this directory you create a project that uses the
specific controller (in this case ATMega8). In the "main.c" you #include
the "universal.c". For this, you have to add the directory path
"..\..\universal" in the compiler settings.
Like this, you can create multiple other subdirectories in the "project"
folder for other controller types and you don't have to create redundand
code.
I hope I explained it understandable :)
