Forum: FPGA, VHDL & Verilog Error in Post-synthesis, ModelSim
von Vinayak S. (vinayak_s)
This is code for finding CRC for all combination of inputs. I cheked
this before synthesis which is working fine but after synthesis giving
error as bellow.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use ieee.numeric_std.all;
entity crc1 is
  port( clk : in std_logic;
        reset: in std_logic;
        input1: in std_logic;
         output1: out std_logic);
  end crc1;
  architecture arch of crc1 is
    signal count2:integer;
    signal b:std_logic_vector(7 downto 0);
       begin
 process(clk,reset)
  begin
    if reset = '1'  then
     count2 <= 0 ;
    elsif rising_edge(clk) then
    if count2 = 1504  then
        count2 <= 1 ;
    else
        count2 <= count2 + 1 ;
    end if;
   end if ;
 end process ;
             process(count2 , reset , b, input1)
               variable i: integer range 0 to 8;
               begin
                 if reset ='1' then
                    b <= "00000000" ;
                    i := 0;
                else
                 if (count2 > 8 and  count2 <= 1504) then
                   if (b(7)='0') then
                      b <= b(6 downto 0) & input1;
                   else
                      b <= ((b(6 downto 0) & input1) xor "11010101" );
                   end if;
                end if;
                end if;
                if (count2 >= 1 and  count2 <= 8) then
                  output1 <= b(i);
                  b(i) <= '0' ;
                  i:= i + 1;
                else
                  i:= 0;
                  output1<= input1;
                end if;
end process;
end arch;
# ** Error: (vsim-3601) Iteration limit reached at time 10 ns.
# ** Note: (vsim-3602) Delays were truncated during elaboration of the
design.
This is usually due to a combinatorial loop. And now lets see...
Here it is:
> i:= i + 1;
A counter without a clock is a combinatorial loop...
But the actaual problem here is another combinatorial loop:
> if (b(7)='0') then
>.   b <= b(6 downto 0) & input1;
> else
>  end if;
This loop will never finish, because the process calculates a new b and
because b(7) has changed the process must be calculated once more. And
on and on and on...
This is also not a good idea:
: Edited by Moderator
