Forum: FPGA, VHDL & Verilog division on the last outputs
von Basma H. (Company: bhit) (basma)
Hi All,
if i have a vector such as (1,2,3,4....100) and i want to use only the
last output 100 to make division on the last output from another vector
such as (5,9,6,8.....200)
i.e i want to divide 100/200 . can i make it in vhdl i don't know if my
question is logic or not or how can i do it.
Show the definition of this "vector".
In what language do you want to solve the problem?
What is the actual problem?
if the first is
[vhdl]
signal dis : integer range 0 to 255 := 0;
signal n   : integer range 0 to 255 := 0;
 and i want to divide the last output from the two signals
and what if there is a zero value in signal n
There is only one value in both of the two signals. So there is no
whatsoever "last value".
Then you are not allowed to perform a division, because the result will
be inpredictable and invalid.
Is this for simulation only or do you want to implement this division in
real hardware?
von basma hassan (Guest)
 the two signal will have values as (1,6,9,8,.....100) and the second
signal will have values as (0,2,8,9.......,200)
and i want to fetch the two last outputs from the two signal (100,200)
and divide 100/200.
> real hardware?
for both simulation and then for implementation in real hardware.
For sure each of the above declared signals n and dis will not take
more than one value.
However, if you have arrays of integer values:
  subtype smallint is integer range 0 to 255;
  signal dis : array (0 to 15) of smallint := 0;
  signal n : array (0 to 15) of smallint := 0;
and the last value inside such an arry is accessed by its posistion:
  signal result : smallint := 0;
  result <= n(15)/dis(15);
Good luck. A division in real hardware is not the easiest thing for a
beginner. But: just start with it, then you will find out to ask the
correct questions...
Here is my code for a division in hardware:
http://www.lothar-miller.de/s9y/archives/29-Division-in-VHDL.html
Its in German, but just try the Google translator...
thanks a lot  Lothar Miller it was very helpful for me ,but if i have a
counter count the number of input samples then the counter output (n)
will be as (1,2,3,4....50) and i want to check if the numbers of samples
is even do that (n*n) or if odd make that ((n*n)-1) and i want to divide
distance which is
to the n numbers of the samples which is even or odd
will e something like that
if lsb = '1' then
 n_of samples<= ((n*n)-1);
else
 n_of_samples <= n*n;
end if;
 norm_dis <= dis / n_of_samples ;
how can i write it in vhdl
i hope y understand me and thanks for help.
 yes you're right sorry for confusing but i am new in vhdl
and the output from the counter gave me a stream values in simulation
mode like (1,2.....,100)
and i want to use the result from the counter to test it and make
division on it. how i can save it and make it in vhdl code
thanks a lot for help
