Forum: FPGA, VHDL & Verilog vhdl code to find max value from input
von basma (Guest)
Hi all,
i want to know how i can find the maximum value from data input
while the data is floating numbers.
i search but didn't find any thing helpe me.
any idea plz....
von Pele (Guest)
i search for it too but didn't found something helpful.
What did you search for?
> any idea plz....
This is exaclty what you need (according to your requirements):
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.math_real.ALL;
entity findmax is
  port (
    clk : in std_logic;
    clr : in std_logic;
    din : in real;
    max : out real;
end findmax ;
architecture Behavioral of findmax is
signal m : real := 0.0;
begin
  process begin
    wait until rising_edge(clk);
      if clr='1' then
        m <= 0.0;
      elsif din>m then
        m <= din;
      end if;
    end if;
  end process;
  max <= m;
end Behavioral;
Of course I already added a clock and a clear signal. Otherwise (without
clock and clear) it would look much less complicated:
library IEEE;
entity findmax is
  port (
    din : in real;
    max : out real;
end findmax ;
begin
  m <= din when m<din else m;
  max <= m;
end Behavioral;
von jeff (Guest)
No semicolon after max: out real
Indeed, but I think that little syntax flaw will not be the biggest
problem here...
von Basma H. (Company: bhit) (basma)
thanks a lot lkmiller ,but i want to know how can i gave the floating
numbers to xilinx simulation program
Basma Hassan wrote:
> but i want to know how can i gave the floating numbers to xilinx
> simulation program
And where do the numbers come from?
Where are the numbers generated and/or stored?
Lothar Miller wrote:
>> simulation program
i mean to test the code i should gave numbers from test bench waveform
instead of write test bench .
I do not understand the problem...  :-/
Please write at least 5 sentences that describe your task (including
answers to my previous questions).
if i want to find the max value in
(0.3251,0.2536,0.2147,0.3669.............)
how to test it and find the max value
Do you remember my unanswered questions?
Show the definition of your data at least. Is it an array of floating
point numbers? How is this array defined?
