Forum: µC & Digital Electronics 16x2 lcd help
von Ajay R. (ajay_r)
Hey,I was working on atmega 8 and tried to use a 16x2lcd with it but lcd
is only showing blocks and nothing else. I want to know whether
something is wrong with my code or with my connections.Here is my code..
#define F_CPU 1000000UL
#include <avr/io.h>
#include <util/delay.h>
#define LCD_DATA PORTB                //LCD data port
#define ctrl PORTD
#define en PD2                         // enable signal
#define rw PD1                       // read/write signal
#define rs PD0                     // register select signal
int main()
DDRB=0xff;                                  // setting the port B
DDRD=0x07;                                // setting for port D
init_LCD();                                 // initialization of LCD
_delay_ms(50);                        // delay of 50 mili seconds
LCD_write_string("“hello world”");                      // function to print string on LCD
return 0;
void init_LCD(void)
LCD_cmd(0x38);                            // initialization of 16X2 LCD in 8bit mode
_delay_ms(1);
LCD_cmd(0x01);                                 // clear LCD
_delay_ms(1);
30
LCD_cmd(0x0E);                        // cursor ON
31
_delay_ms(1);
32
LCD_cmd(0x80);                     // —8 go to first line and –0 is for 0th position
33
_delay_ms(1);
34
return;
35
36
37
void LCD_cmd(unsigned char cmd)
38
39
LCD_DATA=cmd;
40
ctrl =(0<<rs)|(0<<rw)|(1<<en);
41
_delay_ms(1);
42
ctrl =(0<<rs)|(0<<rw)|(0<<en);
43
_delay_ms(50);
44
return;
45
46
47
void LCD_write(unsigned char data)
48
49
LCD_DATA= data;
50
ctrl = (1<<rs)|(0<<rw)|(1<<en);
51
_delay_ms(1);
52
ctrl = (1<<rs)|(0<<rw)|(0<<en);
53
_delay_ms(50);
54
return ;
55
56
57
void LCD_write_string(unsigned char *str)             //store address value of the string in pointer *str
58
59
int i=0;
60
while(str[i]!='\0')                               // loop will go on till the NULL character in the string
61
62
LCD_write(str[i]);                            // sending data on LCD byte by byte
63
i++;
64
65
return;
66
von Henrik P. (henrik84)
a Datasheet of the display module would really help.
I can only guess, maybe the contrast isn't set correctly.
Regards
von Guest (Guest)
RTFM regarding correct initialization. If in doubt use the Fleury
LCD-lib. Reinventing the wheel sometimes is a PITA.
Which type of LCD are you using? They pretend to be compatible but not
all are. What kind of connection between CPU and LCD? One row of black
boxes or two? Have you tried adjusting the contrast voltage?
von Steve (Guest)
What kind of controller does this display use? HD44780(-compatible)?
I think the delay has to be before the initialization of the display,
just after the power was applied.
Steve
von cprog (Guest)
It's even possible the contrast is turned up too high.
von Jake_55 (Guest)
I actually got the circut to work using the code! :D
I havent changed the code in any way and build the circut as you
configured in the code.
But thanks for the code I got mine working now :D
-Jake
