Forum: ARM programming with GCC/GNU tools how to solve this linker script error?
von Hemanth V. (Company: Student) (hemanth)
I created a linker script file as memory.ld –
MEMORY
        MYMEMORY(rw)   : ORIGIN = 0x0041c620 ,  LENGTH = 30
.myvars (NOLOAD) :
  *(.myvarloc)
} > MYMEMORY
In my c program :
__attribute__((section(".myvarloc")))
   uint8 measurements[30];
I am using eclipse IDE on linux rtos. I added –T memory.ld in project –
properties -- linker – libraries – miscellaneous in eclipse I am
creating this because : I want a fixed memory address for the variable
measurements of size 30 starting from 0x0041c620 .
My question : Is it right way of doing this ?? If I do like above : I am
getting error as – Linker input file unused and linking not done.
: Moved by Moderator
von Jörg W. (dl8dtl) (Moderator)
Well, if you are not linking at all, why a linker script?
I guess there won't be much help without knowing the exact
commandline(s)
you are using.
von G. L. (sprintersb)
Presumably, the command line comes with -c -Werror :-)
I added
project –- properties -- C/C++ Build -- Settings -- GCC C linker –-
miscellaneous : -T memory.ld
project –- properties -- C/C++ Build -- Settings -- GCC C compiler –-
Miscellaneous : -c -fmessage-length=0 -std=gnu99
project –- properties -- C/C++ Build -- Settings -- GCC C linker : gcc
-Wall -lrt -pthread -ld
Again, please post your commandlines.  Don't expect others to use the
same IDE as you are using.
Somehow, Eclipse will certainly be able to tell you which commands it is
invoking.
**** Build of configuration Debug for project FEBRUARY ****
make all
Building target: FEBRUARY
Invoking: GCC C Linker
gcc -Wall -lrt -pthread -ld -T -L
/home/user/workspace/FEBRUARY/Debug./memory.ld -o "FEBRUARY"
./src/LocatedVars.o ./src/MAIN.o ./src/xcp.o ./src/xcp_auto_conf.o
./src/xcp_callbacks.o ./src/xcp_cmd.o ./src/xcp_cmdcalpage.o
./src/xcp_cmdchecksum.o ./src/xcp_cmdconnect.o ./src/xcp_cmddaq.o
./src/xcp_cmddownload.o ./src/xcp_cmddyndaq.o ./src/xcp_cmdflash.o
./src/xcp_cmdseednkey.o ./src/xcp_cmdupload.o ./src/xcp_daq.o
./src/xcp_event.o ./src/xcp_stim.o ./src/xcp_target.o ./src/xcpip.o
./src/xcpip_auto_conf.o ./src/xcpip_getrxbuf.o ./src/xcpip_gettxbuf.o
./src/xcpip_init.o ./src/xcpip_peekrxbuf.o ./src/xcpip_resume.o
./src/xcpip_rxcallback.o ./src/xcpip_rxnext.o ./src/xcpip_txcallback.o
./src/xcpip_txnext.o
gcc: error: /home/user/workspace/FEBRUARY/Debug./memory.ld: No such file
or directory
make: *** [FEBRUARY] Error 1
**** Build Finished ****
I am using the IDE and just build it by pressing the ctrl + b.
> -L /home/user/workspace/FEBRUARY/Debug./memory.ld
You are trying to specify the linker script as a linker pathname
(where it is going to search for libraries).  No idea how you can
convince your Eclipse plugin to not insert the -L, you have to read
the plugin documentation.
Also, I guess your memory.ld is actually located at
/home/user/workspace/FEBRUARY/memory.ld rather than in the build
directory.  You probably must prefix it with "../" .  But that won't
help you as long as Eclipse expects your linker script to be a library.
