Forum: FPGA, VHDL & Verilog Need help with reading from file
Author: Miller Jackson (Company: lyt) (slayer1234)
Hi guys,its my first time here in this forum.Firstly,nice to meet you
all.I would like to request help for my assignment as I am having
difficulties at one part of my assignment.
I am trying to read from a file that has 3 columns,and I only need the
middle column,So I declared 2 extra variables to store the left and
right column while another variable(for my input)is used for the middle
column.Attached is my input file and below is my code(reading part).Any
help is greatly appreciated and thanks for taking your time to read my
post.
Input
________
00002180 F31834C2BB6DE27A   U5dªÎy)¨VÔRðfÏ,§
00002190 2F3BED3B8FCDCA36   ó0B”Œ„ B.„
000021A0 01A70C2A1064D71A   B.„ B.„ ”
000021B0 9142F343EAD0CC86   JD B.„ B.„
000021C0 4C640F3EB318FDAE   B.„ B.„
         0FC48AEBAB655950
         670F0E5568CC9F1A
         D8004E3FF2165382
         694AF9ABFBB52758
Code
________________
process
use std.textio.all;
use ieee.numeric_std.all;
file inputfile:text open read_mode is "input8.txt";
variable ipa:std_logic_vector(63 downto 0);
variable ipb:std_logic_vector(63 downto 0);
variable inline:line;
variable ipc:character;
        begin
            while not(endfile(inputfile))loop
                readline(inputfile,inline);
                hread(inline,ipa);
               --data_in<=ipa;
                hread(inline,ipb);
                data_in<=ipb;
                read(inline,ipc);
               --data_out2<=
std_logic_vector(to_unsigned(character'pos(ipc),data_out2'length));
                wait for 800 ns;
          end loop;
          wait;
          end process;
: Edited by User
And whats the problem with that?
I have a kind of a deja vu with the thread
https://embdev.net/topic/321964
Is this the same exercise?
: Edited by Moderator
I am using modelsim,and when I stimulate the code,It shows the input as
000000...,I believe this happened because halfway through the input
file,The left and right column is empty while the middle column(The
input that I want)is continuing,I tested by using the left Column as my
input and just store the other 2 columns(middle,right)into variables and
it works.
So was wondering if it is possible to read the middle column although
the other two columns are empty?
That looks similar to my assignment too,just that my input file is much
longer and the left/right columns goes empty through halfway of the
input file
Thanks for reading and looking forward to your reply!
Author: kaz (Guest)
Maybe this will be useful. There are few assumptions regarding the input
file syntax. Seems to work ok with yours input8.txt .
entity tb is
end;
architecture arch of tb is
begin
  process
    use std.textio.all;
    file OFile:text open read_mode is "input8.txt";
    file OFile2:text open write_mode is "output.txt";
    variable OLine : line;
    variable OLine2 : line;
    variable temp_str : string(1 to 26);
    variable what : boolean:= false;
  begin
    while not(endfile(OFile))loop
      readline(OFile,OLine);
      read (OLine, temp_str,what);
      -- to skip empty lines
      if what then
        -- report temp_str(10 to 26);
        write(OLine2, temp_str(10 to 26));
        writeline(OFile2,OLine2);
      end if;
    end loop;
    file_close(OFile);
    file_close(OFile2);
    report "hello";
  wait;
  end process;
end;
  • [vhdl]VHDL code[/vhdl]
