Forum: ARM programming with GCC/GNU tools Yagarto BUG: static vars are offset in memory by 4 bytes.
von (unknown) (Guest)
I'm using:
yagarto-bu-2.23.1_gcc-4.7.2-c-c++_nl-1.20.0_gdb-7.5.1_eabi_20121222
and it is working well with a project containing dozens of source files.
Then I add the following source files:
FooClass.h
class FooClass {
public:
  FooClass(){};
  static FooFrame m_fooFrame;
FooClass.cpp
#include "FooClass.h"
FooFrame FooClass::m_fooFrame;
Here's the file for the static member:
FooFrame.h
class FooFrame {
public:
  FooFrame(){};
No need for FooFrame.cpp
Trivial right? Well, the result is that static vars are erroneously
shifted in memory by 4 bytes.
Here's the map file. These vars reside at __data_start and are copied
there from ROM by the startup code. Adding FooClass doesn't alter these
vars at the beginning. That's all fine and dandy.
                0x40000200        0x1 src\UserIO.o
                0x40000200                UserIO::m_dummySystemStatus
 *fill*         0x40000201        0x3
 .data._ZN3SAL15m_uart0BaudRateE
                0x40000204        0x4 src\SAL.o
                0x40000204                SAL::m_uart0BaudRate
 .data._ZN3SAL15m_uart1BaudRateE
                0x40000208        0x4 src\SAL.o
                0x40000208                SAL::m_uart1BaudRate
This is the happy memory of the ARM7 before adding FooClass:
40000200 01000000 80250000 80250000 01010100
This is correct. You can see m_dummySystemStatus, and the two baud rates
(9600 baud becomes 0x80250000 :-). Great!
Now lets add FooClass to the project and look at memory:
40000200 FFFFFFFF 01000000 80250000 80250000
What the heck? You can see that the static members have been moved by 1
word (4 bytes) and any code that uses them crashes in a pile.
I'm using James P. Lynch's linker script (modified for the LPC2148):
/*  Author:  James P. Lynch   */        /* identify the Entry Point  */
ENTRY(_startup)
/* specify the LPC2148 memory areas  */
MEMORY
  flash           : ORIGIN = 0,          LENGTH = 512K  /* FLASH ROM                              */
  ram_isp_low(A)    : ORIGIN = 0x40000120, LENGTH = 223    /* variables used by Philips ISP bootloader  */
  ram           : ORIGIN = 0x40000200, LENGTH = 32224  /* free RAM area              */
  ram_isp_high(A)    : ORIGIN = 0x40007FE0, LENGTH = 32    /* variables used by Philips ISP bootloader  */
/* define a global symbol _stack_end  */
_stack_end = 0x40007EDC;
/* now define the output sections  */
SECTIONS
  . = 0;                /* set location counter to address zero  */
  startup : {
    *(.startup)
    . = ALIGN(0x4);
    } >flash    /* the startup code goes into FLASH */
30
31
32
    .text : {
33
        CREATE_OBJECT_SYMBOLS
34
        *(.text .text.* .gnu.linkonce.t.*)
35
        *(.plt)
36
        *(.gnu.warning)
37
        *(.glue_7t) *(.glue_7)
38
39
        . = ALIGN (4);
40
        /* These are for static constructors and destructors under ELF */
41
        KEEP (*crtbegin.o(.ctors))
42
        KEEP (*(EXCLUDE_FILE (*crtend.o) .ctors))
43
        KEEP (*(SORT(.ctors.*)))
44
        KEEP (*crtend.o(.ctors))
45
        KEEP (*crtbegin.o(.dtors))
46
        KEEP (*(EXCLUDE_FILE (*crtend.o) .dtors))
47
        KEEP (*(SORT(.dtors.*)))
48
        KEEP (*crtend.o(.dtors))
49
50
        *(.rodata .rodata.* .gnu.linkonce.r.*)
51
52
        *(.ARM.extab* .gnu.linkonce.armextab.*)
53
        *(.gcc_except_table)
54
        *(.eh_frame_hdr)
55
        *(.eh_frame)
56
57
        *(.init)
58
        *(.fini)
59
60
        PROVIDE_HIDDEN (__preinit_array_start = .);
61
        KEEP (*(.preinit_array))
62
        PROVIDE_HIDDEN (__preinit_array_end = .);
63
        PROVIDE_HIDDEN (__init_array_start = .);
64
        KEEP (*(SORT(.init_array.*)))
65
        KEEP (*(.init_array))
66
        PROVIDE_HIDDEN (__init_array_end = .);
67
        PROVIDE_HIDDEN (__fini_array_start = .);
68
        KEEP (*(.fini_array))
69
        KEEP (*(SORT(.fini_array.*)))
70
        PROVIDE_HIDDEN (__fini_array_end = .);
71
    } >flash
72
73
    /* .ARM.exidx is sorted, so has to go in its own output section.  */
74
    .ARM.exidx : {
75
        __exidx_start = .;
76
        *(.ARM.exidx* .gnu.linkonce.armexidx.*)
77
        __exidx_end = .;
78
    } >flash
79
    _etext = .;
80
81
82
83
    .data : {
84
        __data_load = LOADADDR (.data);
85
        __data_start = .;
86
        KEEP(*(.jcr))
87
        *(.got.plt) *(.got)
88
        *(.shdata)
89
        *(.data .data.* .gnu.linkonce.d.*)
90
        . = ALIGN (4);
91
        _edata = .;
92
    } >ram AT >flash
93
94
    .bss : {
95
        __bss_start__ = . ;
96
        *(.shbss)
97
        *(.bss .bss.* .gnu.linkonce.b.*)
98
        *(COMMON)
99
        . = ALIGN (4);
100
        __bss_end__ = .;
101
    } >ram
102
103
104
  _end = .;              /* define a global symbol marking the end of application RAM */
So my question is, can you help me identify where I'm going wrong?
Thank you!
David
von (prx) A. K. (prx)
Build a minimzed testcase which allows others to reproduce the problem.
von Jörg W. (dl8dtl) (Moderator)
Make this either 0x40007ed8, or 0x40007ee0.  It's not immediately
obvious to me whether your problem might fall into this, but I've once
stumbled across that one myself (on a Cortex-M3 though).
Thank you for the reply. I've tried both addresses and it did not fix
the problem. Were you thinking that the address should be on a word
boundary?
I am also working to reduce this problem to a small size test case so
that I can post the entire project.
In the mean time I am using static pointers to classes and initializing
them through constructors. It is distasteful, but so is most of my work
recently.
Cheers,
David
von Dr. Sommer (Guest)
>         __data_start = .;
Can you verify that those addresses are correctly set?
David Lee wrote:
> Were you thinking that the address should be on a word boundary?
On a 64-bit boundary.  This is the maximum alignment requirement in ARM
cores (for “double” values).
von Uwe Bonnes (Guest)
Can you try with a recent arm gcc from
https://launchpad.net/gcc-arm-embedded?
I will work on this today. Thanks!
Hi Uwe,
Thank you for the suggestion (and implicit encouragement).
I upgraded from Yagarto's gcc-4.7.2 to launchpad's 4.8-2013-q4-major.
The offset problem is gone. My code runs fine now.
I have a question for all. Do new version of cross gcc for ARM introduce
as many bugs as they fix? Is successful development a matter of just
finding the version that compiles "your code" correctly?
Cheers to all,
David
von MarcVonWindscooting (Guest)
A "cross gcc" is not that much different from a "normal" gcc for your
host system.
My experience is: gcc is much more reliable than the programs I write
myself. MEANING: errors that show up are almost always MY errors.
Switching to another gcc does not necessarily mean your problem is gone.
It might as well have gone because the conditions have changed a bit:
new segments/removed segments/different code size/different arrangement
of segments/alignment/...(a million other possibilities)...
Have you searched a bug tracker for something that sounds like your
problem?
If your problem is a gcc problem and it shows up only rarely then the
gcc developer would definitely appreciate you reporting that bug.
Because one thing is true about bugs: they persist and show up at the
most inappropriate moment in a project...
