Forum: FPGA, VHDL & Verilog Single Entity - Multiple architectures
von SM (Guest)
I am a beginner in VHDL, I have a very basic question regarding Single
Entity having multiple architectures. For example when the VHDL code is
compiled (a single file containing one entity and 3 architectures), how
does the compiler will decide which is the default architecture; or
there isn't anything like Default Architecture.
I will be really grateful to any help from experts here.
Thanks in advance.
von cfgardiner (Guest)
In the VHDL standard this is defined in the chapter on "default Binding
Indication". VHDL differentiates between Primary design units (Entity,
Package Header, Configuration) and Secondary design units (architecture
body, package body).
You must compile (well, analyse in the VHDL terminology) a primary
design unit first. Sort of logical if you think about it, except perhaps
for configurations. Configurations only become 'real' at elaboration
time, i.e. after you have analysed everything into a library and are
building your model, starting your simulation or whatever.
If you compile multiple secondary units and don't specify a binding
(e.g. link a specific architecture to a specific entity) then the
default binding is the "most recently analysed" architecture .... the
last one analysed.
Charles
: Edited by Moderator
