Forum: FPGA, VHDL & Verilog how to implement interleaver in FPGA
Author: Vinayak S. (vinayak_s)
Hi..........
I attached image of DVB-T2 "Bit-Interleaver" in that columns and Rows
are given. This is for 16-bit QAM and length is 64800-bits. This divided
into 8100 rows and 8 columns. The data coming from previous block is
"one Bit per Cycle". First bit store in 0th location like that First
8100 bits should store and later shift these bits circularly(ROTATE)
according a "twisting parameter tc" listed in table below. Next 8100
also twist and store...so on up to 8 columns...
Write into Buffer(storage) as ROW wise:-
input indexs:         0 1 2 3 4 5 6 .... 8099
after circular        0 1 2 3 4 5 6 .... 8099
shitf using "tc=0"
if "tc=2" then        0     1     2 3 4 5 6 .... 8099
                     8099   8098  0 1 2 3 4 5 ...8097
  this is upto 64800 bits and Reading(output) these twisted bits as
column wise..like 0th location bit first,8099th second,serillaty
16199,24298,32397,40496,48595,56694,64793, 1, 8100, 16200...so on.....
I design using signal and variables in VHDL which is not
synthesizing....
help me what best way of implimentation....
Author: Schlumpf (Guest)
> synthesizing....
Do you really think it is a good idea to start learning VHDL with a
project like this?
Author: Vinayak S. (Guest)
I'm doing internship in company and they give me project like this. And
more over i need to submit project for my PG..
so, i started well but i stuck at here pls guide me how to implement
i'll do my best..
You do internship and there is nobody guiding you a little bit?
Well, you have to implement one ore more shift registers and a control
logic.
If it is not synthesizing it is not a matter of the usage of signals and
variables. You asked this in another post and got a answers where the
problem might be.
Author: Lattice User (Guest)
> i'll do my best..
This begs the question what is the task you have been given:
Complete DVB-T2 modulator or demodulator or just parts like the
interleaver?
complete DVB-T2 modulator....
> synthesizing....
Vinayak S. wrote:
> internship
I think you are not very familiar with FPGA and HDL and digital design.
Is that right?
If yes, what kind of help do you expect? Complete source code? A couple
of hints how to start with the problem?
If you are a beginner in VHDL you will fail to implement a DVB-T2
modulator within an internship.
Author: dden (Guest)
1 useful
Hello,
first of all if you want to implement only the 16-Qam with 64800_BITS
then you need exactly 4050_Bytes so your RAM should have a size of
4096_Bytes or 32768_BITS.
But also if YOU want to implement a ""complete" DVB-T2 whatever" this
will be an easy Task compared to other Sections.
And if you still want to implement this then my Tipp is use an ram two
counters and a State-Machine to control the flow, the Diagramm already
shows you how.
Author: world's best FPGA-Pongo (Guest)
To my mind, one should distinguish the subsequent issues:
1) Learning Digital Design and Digital Behavior
2) Learning Implementation of logic fuctions in digital domains
3) Learning VHDL to realize the ideas
4) Learning about the particular task
I see demand in all those aspects so I second the sencence above that
this task is no good for beginning.
Anyway one should at least be able to write down a step be step task
list, what the interleaver should do at any point of time, where data is
obtained from and moved to, and what treatment is applied. Graphical
diagrams will help to express people's thougths and indicate any
misunderstandings to people in the forum.
Also I have to point out that it is no good to ask silently here in the
forum. Ask the one who gave you the task, so that he has a feed back
about your knowledge. If you do no do this, he will continue to
verestimate your abilities and overload you with work.
  • [vhdl]VHDL code[/vhdl]
