Forum: µC & Digital Electronics Interesting experiments with ADSL splitter
Author: Thinh Nghiem (thinhnghiem)
As we know, the ADSL splitter box has 1 input and 2 outputs, one for
phone signal line, and the other for internet signal line
I have executed many experiments with this device, and some give out
interesting results. I list here 5 of them. Their schemas can be found
in the attached screenshot
Experiment a)
Plug the telecommunication line into the input. Then in the output
lines, I make the swapping. I plug the phone line to the internet
output, and the internet line to the phone output
Then I dial the phone to call to a fax number
Surprisingly, I heard the busy tone, instead of fax tone.
Note: When I connect in normal way, plug the phone line to the phone
output, and internet line to the internet output, this effect does not
happen. That means I heard the fax tone as usual
Experiment b)
I make the looping back from the net output to the input. To do this, I
cut into the cable and heal the wire inside, with the same color
correspondingly (green to green, red to red)
Then, I connect phone output to a telephone machine.
Result: No tone heard when I picked up the phone machine
Experiment c)
I make the connection between phone output and net output, by cutting
into the cable and healing the wire inside, with the same color
correspondingly (green to green, red to red), similarity as I did in
experiment b)
Experiment d)
Wall line is plugged into the net output (Not the input). Then, I make
the looping back from the phone output to the input. To do this, I cut
into the cable and heal the wire inside, with the reverse color
correspondingly (green to red, red to green)
Then, I connect input line to a telephone machine.
Note: If I repeat the same experiment by healing the wire with the same
color correspondingly (green to green, red to red), no issue happens.
The tone can be heard from the phone machine
Experiment e)
Wall line is plugged into the phone output (Not the input). Then, I make
the looping back from the net output to the input. To do this, I cut
Then, I connect input line to a modem to emit Internet signal
Result: No internet signal is created
Author: Easylife (Guest)
Did you also try to throw the splitter out of the window from 3rd floor,
heal the housing with duct tape, connect it to a TV input and look what
kind of picture you see.
Could be interesting, try it, I would be interested to hear about the
results.
Author: matzetronics (Guest)
1 useful
Hmm, still looking for any question in this posting. For your info -
this all is not really surprising.
The Splitter basically consists of a highpass for the DSL Signal and a
lowpass for the telephone line.
Sometimes the DSL output is simply wired to the input as most DSL input
circuitries in Modems provide the highpass themselves. Teardown a
splitter and extract the circuit, its a really simple thing. I have
built a splitter myself when the guys forgot to send me one and it
simply consisted of two coils in the a/b lines and a condenser for the
telephone - worked perfectly.
Author: trolley (Guest)
> built a splitter myself ...
... after doing your experiment, Easylife.
