Forum: µC & Digital Electronics ATMEGA8 unable to take input
Author: Ajay R. (ajay_r)
I am working on atmega 8 .I am new to it ,and making a program that will
glow a led on one pin depending on the input in another pin ie if input
is 5v led will glow otherwise it will not.But i guess something is wrong
with my program.
#define F_CPU 1000000UL
#include <avr/io.h>
#include <util/delay.h>
int main (void)
{DDRB=0x03;
PORTB=0x00;
while(1)
if(PINB && 0b00000001)
PORTB=0x02;
else
PORTB=0x00;
: Moved by Moderator
Author: Jörg Wunsch (dl8dtl) (Moderator)
“&&” is a logical AND.
What you (probably) want is a bitwise AND though, which is “&”.
After few days i was able to overcome the problem in the code,my new
code:
 #include <avr/io.h>
int main(void) {
    DDRC = 0xFF;
    DDRB = 0;
    PORTB = 0;
  PORTC=0b00000000;
    while (1) {
if(PINB==0b00000001)
        PORTC = 0b00000001;
    else
    PORTC=0;
But still there is some problem,the led is turning off when i connect
the input to ground but when the input is not grounded the led glows and
when input is connected to 5v led glows but slight brightly.I want to
know why is led not turning off completely when there is no
input(neither ground nor 5v).
Author: karl heinz (Guest)
1 useful
because it is a common misconception, that an input pin, which is not
connected to anything, gives a value of 0.
In fact, that pin is nothing more then an antenna, which reacts on any
electromagnetic field nearby. And there are lots of them. Eg all the
power cords in the wall, your mobile phone, ther µc itself, etc. etc.
Exactly this is, why we use pullup or pulldown resistors, which
guarantee a specific value on an input portpin, even if the usual switch
is not closed.
#include <avr/io.h>
int main(void) {
    DDRC = 0xFF;
    DDRB = ( 1 << PB0 );   // turn on pullup resistor
                           // to guarante, that the portpin will
                           // give a 1 Bit, even if there ist nothing
                           // connected to it
    PORTC = 0b00000000;
    while (1) {
      if( PINB & ( 1 << PB0 ) )
        PORTC |= ( 1 << PC0 );
      else
        PORTC &= ~( 1 << PC0 );
and familiarize yourself with C-bitoperations. They are your 'working
horse' in µC-programing!
Sorry. My fault
#include <avr/io.h>
int main(void) {
    DDRC = 0xFF;
    PORTB = ( 1 << PB0 );   // turn on pullup resistor
                           // connected to it
you need to set a 1 Bit in the PORTx Register, to turn on the pullup
resistor for that pin, if the pin is an input pin.
Thanks...can you suggest me a source from where i can learn basic c-bit
operations,i know how to use them but find it little confusing when
using it with avr.
1 useful
Well. Any C Progamming book should do.
Unfortunately I don't know any english written Tutorial for the topic of
bit-operations.
In a Nutshell:
to turn a bit to 1
     register |= ( 1 << bitnumber );
to turn a bit to 0
     register &= ~( 1 << bitnumber );
to check if a bit is 1
   if( register & ( 1 << bitnumber ) )
to check if a bit is 0
   if( !(register & ( 1 << bitnumber ) )
look up the operators & | << >> and ~ in the C textbook of your choice.
Author: moez mallat (Guest)
S'il vous plaît entrer un texte plus long.
Author: Vazgen Gabrielyan (viig)
If you know russian i can send you a very detailed tutorial in russian
about the avr and really simple examples and how to use them..
