Forum: FPGA, VHDL & Verilog Not synthesizing
Author: Vinayak S. (vinayak_s)
Hi.....
I used signal(0 to 64800)integer in VHDL and which is not
synthesizing....
Insted of using signal/variable is there any method we can use for large
values.... ?
Ex:
Buf1(64799 downto 0);--integers
Author: Innensechskant (Guest)
I can't see any problem with the declaration shown.
Please post complete and minimal code which shows the problem along with
the error message(s). In case of VHDL this consists an entity and an
appropriate testbench.
Here I used temp0 as signal which is not synthesizing....Which code as
shown below help me out in this issue....
modelsim 6.5 working fine but for xilinx 10.3 which is not
synthesing.....
library ieee ;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use ieee.numeric_std.signed;
entity parity_int is
  port( clk : in std_logic;
        reset: in std_logic;
        nm_sh_sel:in std_logic;
        code_rate:in std_logic_vector(3 downto 0);
        K_ldpc: in std_logic_vector(15 downto 0);
        N_ldpc:in std_logic_vector(15 downto 0);
        input1: in std_logic;
        output1: out std_logic);
  end parity_int;
  architecture arch of parity_int is
  --Both normal and short are in one array. if we select normal then it gives 0 to 9 and
  -- if we select the short then code_rate plus 6 need to add.
  type Q_ldpc_normal is array (0 to 14) of integer;
  constant Q_ldpc:Q_ldpc_normal:=(90,72,60,45,36,30,36,30,27,25,18,15,12,10,8);
  signal count1:integer;
  signal s:integer;
  signal t:integer;
  signal temp0:std_logic_vector(0 to 64799);
  signal cd_rate:std_logic_vector(3 downto 0);
  begin
  cd_rate <= code_rate when nm_sh_sel = '0' else code_rate + 6 ;
    process(clk,reset)
       begin
         if((clk'event and clk = '1') or reset = '1') then
           if reset = '1' then
             count1 <= 0;
           else
             if count1 = to_integer(unsigned(N_ldpc))+to_integer(unsigned(K_ldpc)) + 1 then --32400+64800
               count1 <= 0;
             else
             count1 <= count1 + 1;
           end if;
         end if;
       end if;
     end process;
      process(count1,t)
       begin
           if reset = '1' then
             s <= 0;
           else
             if count1 >= to_integer(unsigned(K_ldpc)) + 1 and count1<to_integer(unsigned(N_ldpc)) +1 then
             if s = 360 then
                s <= 0;
             else
                s <= s + 1;
           end if;
         end if;
       end if;
     end process;
      process(count1)
       begin
           if reset = '1' then
             t <= 0;
           else
             if count1 >= to_integer(unsigned(K_ldpc)) + 1 and count1 < to_integer(unsigned(N_ldpc)) + 1 then
             if t = Q_ldpc(to_integer(unsigned(cd_rate)))   then
                t <= 0;
             else
               if s = 360 then
                t <= t + 1;
              end if;
           end if;
         end if;
       end if;
     end process;
     process(count1,reset)
       begin
         if count1 >= 1 and  count1 < to_integer(unsigned(K_ldpc)) + 1  then
         temp0(count1 - 1) <= input1; -- it took one extra cycle because input delay by one cycle...
       elsif count1 >= to_integer(unsigned(K_ldpc)) + 1 and count1 < to_integer(unsigned(N_ldpc)) + 1 and t < 90 then
         temp0(to_integer(unsigned(K_ldpc)) + (360 * t) + s ) <= input1;
         output1 <= temp0(count1 - to_integer(unsigned(K_ldpc)) - 1);----32401-32400-1=0
       elsif count1 >= to_integer(unsigned(N_ldpc)) + 1 and count1 < (to_integer(unsigned(N_ldpc)) + to_integer(unsigned(K_ldpc)) + 1) then
       end if;
end process;
end arch;
: Edited by Moderator
The file extension for VHDL files is "vhd".
Please use tags as mentioned in the "formatting" section.
It is most likely that you got some warnings and errors.
At least because:
does not declare an integer in the range from 0 to 64799 but a
standard logic vector (i.e. a bit vector) with indixes 0 to 64799
instead which is far to large, to broad, to be synthesized.
I'm sorry: It must be: "... which is far too large, too broad, to be
synthesized."
You really don't know what you are doing? Just digging around?
Take these two:
Or those:
Or (much better) this one:
But never ever use all of them together!!
This forms a combinatorial loop:
      process(count1,t)
       begin
           if reset = '1' then
             s <= 0;
           else
              s <= s + 1;
You just don't see it in simulation because the sensitivity list is
incomplete: s is missing...  :-/
Same for t in the following:
      process(count1)
       begin
           if reset = '1' then
             t <= 0;
           else
                t <= t + 1;
And what the heck is this:
    process(clk,reset)
       begin
           if reset = '1' then
             count1 <= 0;
           else
             if count1 =
               count1 <= 0;
             else
A kind of asynchronous reset hidden in the clocked part of a process?
Where did you find this way of VHDL coding?
Vinayak S. wrote:
> modelsim 6.5 working fine but ...
... your simulation is wrong because of the mostly incomplete
sensitivity lists.
No worth in mentioning all the other ... hmm ... peculiarities.
An attempt to write a DVB-T decoder
(http://embdev.net/topic/322606#3509435) which on the other hand does
not know basic datatypes... Waste of time.
Thank you for valuable reply....
 process(clk,reset)    ---- counter
    begin
      if reset='1' then
        count1 <= 0;
      elsif rising_edge(clk) then
        count1 <= 0;
        if count1 =64800 then
          count1 <= 0;
        else
        end if;
      end if;
  end process;
I modified counter program like that "THIS WAY IS GOOD"....?
Yes, because thats the usual way to describe a counter.
Apart from the asynchronous reset and the fact that one line isn't
necessary:
      count1 <= 0;    -- not useful and not necessary
         count1 <= 0;
      else
Thank you for correcting......
I stack in designing pls help me.....
What is the solution for large values like 64800*8 interger values need
to store in register/buffer before using this reg/buf.
Means to say I have store large values of Address and utilize them in
program.
Author: Falk (Guest)
@Vinayak S. (vinayak_s)
No, you are lacking basic knowledge of VHDL and digital design.
VHDL ist NOT just another programming language!
It is, as the name implies, a hardware description language.
A RAM. Available in any decent FPGA.
>program.
Just do it. After you did your homework and got a grip of the basics.
Otherwise, forget it.
Author: Schlumpf (Guest)
What do you want?
An integer which can store values in the range from 0 to x ?
or do you want to have a signal that contains x bits?
e.g.
integer range 0 to 1023 will "produce" a 10bit wide Signal which can
contain values from 0 to 1023
std_logic_vector(1023 downto 0) will "produce" a 1024bit wide signal
which can contain 2^1024 different binary values (0 to something very
very large)
Its about 64800*16-bit and I need it for 8 signals/array in VHDL....
1.3 MBits embedded memory nowadays is in every upper range FPGA.
WHICH one do you use?
WHAT is your actual problem? WHAT task do you have to solve?
HOW could anyone help you? You don't answer any question, instead you
only repeat useless facts like a mantra...
I`m using "Spartan 3A DSP".
I require memory of 64800*16*8=7Mbits......
so you will have to connect it externally. And of course you cannot
implement that simply with one line of code in your VHDL description.
Instead you must implement a RAM controller to access the external
memory.
But: maybe you simply overestimate your secret problem...
For what? Where does the data come from? Where does it go to? In what
way must the data be manipulated? What data rates do you need on the
whole system? 5 questions waiting for at least 5 answers.
I`m designing interleaver which does`t have input output formule. Means
if first bit comes it should be place in 100th positon like that or
output first bit at 100th place... In a system like that 64800 bits need
to interleave before sending. previously I store it in signal but which
not synthesize so i think for RAM/ROM...
here also got memory problem there are 8 different interleaving methods.
Means 64K into 8 different file(to store data).
Author: dden (Guest)
What the heck should this be?
and why you need 8x64k for that, if its a temporary buffer you'll need
it just once.
And why do you need a FPGA for that?
Its a part of project of DVB-T2. I have to save all values no option.
Author: Lattice User (Guest)
DVB-T2 ist the most komplex existing TV broadcast standard. Trying to
implement it on a Spartan3A is akin trying to build a Formula I racing
car using a Tata chassis.
The largest Spartan3A DSP has only about 2Mbit block ram.
Hello,
just looked at the dvb-t2 standart, are you implementing a FECFRAME
Bit-Interleaver?
Yes, I`m implimenting a "Bit Interleaver"...
I also refereeing same PDF only... I also implemented Interleaver but
which not synthesizing for large buffer I used and I asked solution for
many: what they told is go with RAM/ROM implementation but now facing
problem of momory.. for differnt Nldpc or Qldpc, values to be interleav
is change. so only I`m asking is there any other way of implementation
or how effectively use RAM/ROM....
pls refer figure attached........
: Edited by User
  • [vhdl]VHDL code[/vhdl]
