Forum: FPGA, VHDL & Verilog Signal cannot be synthesized
von Marko A. (markanjski)
Hi guys,
I have to write a program in VHDL language in the Xilinx development
environment, which later need to load the FPGA. Checking syntax (Check
Syntax) throw a couple of errors. I solve them. Starting procedure
Configure Device (iMPACT). And then I get the message:
   "Signal wtp cannot be synthesized, bad synchronous description."
Please someone help me. Sorry for bad English. This is my code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity main is
    Port ( cp, o1, o2, rst : in  STD_LOGIC;
           piz, wt : out  STD_LOGIC;
        seg : out std_logic_vector (6 downto 0);
        cet : out std_logic_vector (3 downto 0)
end main;
architecture behavioral of main is
signal broj : integer range 0 to 30;
signal seg1, seg2 : std_logic_vector (6 downto 0);
signal cpd : std_logic;
begin
s1 : entity work.djelitelj port map(cp, cpd);
s2 : entity work.buzzer port map(cp, broj, piz);
s3 : entity work.numbers port map(cp, broj, seg1, seg2);
s4 : entity work.display port map(cp, seg1, seg2, seg, cet);
30
31
process(cp, o1, o2, rst)
32
variable e, q : integer range 0 to 2;
33
variable wtp : std_logic;
34
variable brnew : integer range -30 to 30;
35
begin
36
37
if(rst'event and rst='1')then
38
   brnew:=-broj;
39
end if;
40
41
if(o1'event and o1='1' and e=0)then
42
   q:=1;
43
elsif(o1'event and o1='1' and e=1)then
44
   wtp:='1';
45
  e:=0;
46
end if;
47
48
if(o2'event and o2='1' and q=1)then
49
   brnew:=1;
50
  wtp:='0';
51
  q:=0;
52
elsif(o2'event and o2='1' and q=0)then
53
   e:=1;
54
end if;
55
56
57
58
wt<=wtp;
59
broj<=broj+brnew;
60
brnew:=0;
61
end process;
62
end behavioral;
And thats only the tip of an iceberg...
First lets get clear what components you have inside a FPGA for your own
Hardware. Its fairly simple, there are only two of them:
1. Logic Cells (LUTs)
2. D-Flipflops
With those two components the synthesizer must try to implement your
hardware description.
And now lets have a look at your code:
   wtp:='1';
   e:=0;
end if;
   brnew:=1;
   wtp:='0';
   q:=0;
In VHDL a 'event means: implement a D flipflop on the following signals.
So wtp will be implemented as a D flipflop. And what does a D flipflop
look like? How many clock inputs does it have? Whey does the synthesizer
fail trying to implement wtp as a D flipflop?
Going one step back I can say: your description is obviuosly from a
software programmer first time trying to do VHDL. Where did you find
that extensive use of variables? Who told you to use 5 different clocks
in 1 process? Where did you find this curious way to describe clock
enables?
: Edited by Moderator
