Forum: µC & Digital Electronics ATMEGA8 beginner problem
von Ajay R. (ajay_r)
I'm using ATmega 8 (8L - 8PI) , I am trying to blink two LED's in
alternate order with legs PB0 and PB6 for each LED's but its not
working..
‪#‎define F_CPU 1000000UL
‪#‎include <avr/io.h>
#include <util/delay.h>
int
main (void)
DDRB |= _BV(DDB0);
DDRB |= _BV(DDB6);
while(1)
PORTB = 00000001;
_delay_ms(500);
PORTB = 01000000;
_delay_ms(500);
: Edited by Admin
Ajay R. wrote:
> but its not working
WHAT is not working?
two leds are not blinking...only one is blinking
von MWS (Guest)
Ajay R. wrote:
> PORTB = 01000000;
You need to tell the compiler it's a binary expression.
I am new to this(noob),can you please modify my code.
converting it to hexadecimal form would help??
von Hartl192 (Guest)
Ajay R. wrote:
> PORTB = 00000001;
> _delay_ms(500);
> PORTB = 01000000;
Try it like this:
 PORTB = 0x01;
> _delay_ms(500);
> PORTB = 0x40;
von A.S.M. (Guest)
Ajay R. wrote:
 while(1)
 PORTB = 0b00000001;
 _delay_ms(500);
 PORTB = 0b01000000;
 _delay_ms(500);
von MWS (Guest)
You already got the hint ;D
Btw., I think binary representation is the better translation.
For the compiler 01000000 is a number, one million, which doesn't fit a
port of 8 bit very well. 0b01000000 will do a better job.
von Karol B. (johnpatcher)
Adopt your main loop to look something like this:
PORTB = 0x01;
_delay_ms(500);
PORTB = 0x40;
_delay_ms(500);
Alternatively, if you are using avr-gcc, you can also make use of the
"0b" notation:
PORTB = 0b00000001;
_delay_ms(500);
PORTB = 0b01000000;
_delay_ms(500);
Best regards,
Karol Babioch
Thanks to all of you,its working now :D
Well, you should try to understand what was wrong with your notation in
order to learn something from your mistake ;).
Best regards,
Karol Babioch
> Best regards,
> Karol Babioch
Karol can you name a book or give a link from where i can learn basic
AVR,I understood what i did wrong but want to further expand my
knowledge.
Thanks in advance
And also you should have learned, that its not enough to say:
Its not working!
> Its not working
Ok,from now on i will be specific about the problem i faced.
