I am new to vhdl and while coding i want to invert a cetain number of
bits in a signal. the code is somewhat like this:
1 | signal flag : STD_LOGIC_VECTOR(31 downto 0) := (others => '0') ;
2 | signal first_part : STD_LOGIC_VECTOR(31 downto 0) := (others => '0') ;
3 | signal second_part: STD_LOGIC_VECTOR(31 downto 0) := (others => '0') ;
now i want to do something like this, the
in a previuos parts of the code copies a number of bits from an fpga
stream, whose number of bits is variable but not more than 3. For
example if the maximum number of bits are copied into
are 3, 001, in first case, in second case 01. however, the order of
bits in
is inverted and 1 is missing. i.e the actual output for 001 is 1100, so
i have to add 1 at the 4th position and also invert the order of 001 to
100. also for second case (01) the output should be 110 after attaching
1 at the third position.
the
contains the copied bits from the stream, signal flag contain the
actual no bits, either 111 for 001 or 11 for 01 and
contains the final inverted form. Here, i want to ask that if the do
the following, would it achieve my purpose without error:
1 | first_part(0) <= '1';-- because i want to attach the missing 1.
2 | --also first_part(31 downto 1) the signal contains bits "0000000000000000000000000000001" and corresponding flag signal wud be "0000000000000000000000000000111"
3 | second_part(31 downto 4) <= "0000000000000000000000000000"--padding with zeros bc max number of bits to be used for this signal are 4.
4 | second_part(3 downto 0)<= first_part(0 to 3) if flag(2)='1' or '0' & first_part(0 to 2) if flag(1)='1' or "00" & first_part(0 to 1) if flag(0)='1' or "000" & first_part(0) if flag(0)='0';
I want to ask if this will in first case put value 1100 in
and in second case put value 110 in
Any help is appreciated.
