1 | library ieee;
2 | use ieee.std_logic_1164.all;
3 | use ieee.std_logic_unsigned.all;
4 |
5 | entity uart is
6 | port (
7 | reset :in std_logic;
8 | txclk :in std_logic;
9 | ld_tx_data :in std_logic;
10 | tx_data :in std_logic_vector (7 downto 0);
11 | tx_enable :in std_logic;
12 | tx_out :out std_logic;
13 | tx_empty :out std_logic;
14 | rxclk :in std_logic;
15 | uld_rx_data :in std_logic;
16 | rx_data :out std_logic_vector (7 downto 0);
17 | rx_enable :in std_logic;
18 | rx_in :in std_logic;
19 | rx_empty :out std_logic
20 | );
21 | end entity;
22 | architecture rtl of uart is
23 | -- Internal Variables
24 | signal tx_reg :std_logic_vector (7 downto 0);
25 | signal tx_over_run :std_logic;
26 | signal tx_cnt :std_logic_vector (3 downto 0);
27 | signal rx_reg :std_logic_vector (7 downto 0);
28 | signal rx_sample_cnt :std_logic_vector (3 downto 0);
29 | signal rx_cnt :std_logic_vector (3 downto 0);
30 | signal rx_frame_err :std_logic;
31 | signal rx_over_run :std_logic;
32 | signal rx_d1 :std_logic;
33 | signal rx_d2 :std_logic;
34 | signal rx_busy :std_logic;
35 | signal rx_is_empty :std_logic;
36 | signal tx_is_empty :std_logic;
37 | begin
38 | -- UART RX Logic
39 | process (rxclk, reset) begin
40 | if (reset = '1') then
41 | rx_reg <= (others=>'0');
42 | rx_data <= (others=>'0');
43 | rx_sample_cnt <= (others=>'0');
44 | rx_cnt <= (others=>'0');
45 | rx_frame_err <= '0';
46 | rx_over_run <= '0';
47 | rx_is_empty <= '1';
48 | rx_d1 <= '1';
49 | rx_d2 <= '1';
50 | rx_busy <= '0';
51 | elsif (rising_edge(rxclk)) then
52 | -- Synchronize the asynch signal
53 | rx_d1 <= rx_in;
54 | rx_d2 <= rx_d1;
55 | -- Uload the rx data
56 | if (uld_rx_data = '1') then
57 | rx_data <= rx_reg;
58 | rx_is_empty <= '1';
59 | end if;
60 | -- Receive data only when rx is enabled
61 | if (rx_enable = '1') then
62 | -- Check if just received start of frame
63 | if (rx_busy = '0' and rx_d2 = '0') then
64 | rx_busy <= '1';
65 | rx_sample_cnt <= X"1";
66 | rx_cnt <= X"0";
67 | end if;
68 | -- Start of frame detected, Proceed with rest of data
69 | if (rx_busy = '1') then
70 | rx_sample_cnt <= rx_sample_cnt + 1;
71 | -- Logic to sample at middle of data
72 | if (rx_sample_cnt = 7) then
73 | if ((rx_d2 = '1') and (rx_cnt = 0)) then
74 | rx_busy <= '0';
75 | else
76 | rx_cnt <= rx_cnt + 1;
77 | -- Start storing the rx data
78 | if (rx_cnt > 0 and rx_cnt < 9) then
79 | rx_reg(conv_integer(rx_cnt) - 1) <= rx_d2;
80 | end if;
81 | if (rx_cnt = 9) then
82 | rx_busy <= '0';
83 | -- Check if End of frame received correctly
84 | if (rx_d2 = '0') then
85 | rx_frame_err <= '1';
86 | else
87 | rx_is_empty <= '0';
88 | rx_frame_err <= '0';
89 | -- Check if last rx data was not unloaded,
90 | if (rx_is_empty = '1') then
91 | rx_over_run <= '0';
92 | else
93 | rx_over_run <= '1';
94 | end if;
95 | end if;
96 | end if;
97 | end if;
98 | end if;
99 | end if;
100 | end if;
101 | if (rx_enable = '0') then
102 | rx_busy <= '0';
103 | end if;
104 | end if;
105 | end process;
106 | rx_empty <= rx_is_empty;
107 |
108 | -- UART TX Logic
109 | process (txclk, reset) begin
110 | if (reset = '1') then
111 | tx_reg <= (others=>'0');
112 | tx_is_empty <= '1';
113 | tx_over_run <= '0';
114 | tx_out <= '1';
115 | tx_cnt <= (others=>'0');
116 | elsif (rising_edge(txclk)) then
117 |
118 | if (ld_tx_data = '1') then
119 | if (tx_is_empty = '0') then
120 | tx_over_run <= '0';
121 | else
122 | tx_reg <= tx_data;
123 | tx_is_empty <= '0';
124 | end if;
125 | end if;
126 | if (tx_enable = '1' and tx_is_empty = '0') then
127 | tx_cnt <= tx_cnt + 1;
128 | if (tx_cnt = 0) then
129 | tx_out <= '0';
130 | end if;
131 | if (tx_cnt > 0 and tx_cnt < 9) then
132 | tx_out <= tx_reg(conv_integer(tx_cnt) -1);
133 | end if;
134 | if (tx_cnt = 9) then
135 | tx_out <= '1';
136 | tx_cnt <= X"0";
137 | tx_is_empty <= '1';
138 | end if;
139 | end if;
140 | if (tx_enable = '0') then
141 | tx_cnt <= X"0";
142 | end if;
143 | end if;
144 | end process;
145 | tx_empty <= tx_is_empty;
146 |
147 | end architecture;
