Forum: FPGA, VHDL & Verilog comparator in vhdl-ams
von sebgimi (Guest)
Hi all! I would like to write a code for a comparator in vhdl-ams. Its
the first time I use this langage so I'm totally lost... (by the way if
you know a link with complet lesson on this langage it will be great).
Anyway, I find a simple code on the web, but when I run the entity only,
the following error is occuring:
library ieee;
use ieee.std_logic_1164.all;
use ieee.electrical_systems.all;
entity comparator is
--generic (level : Real := 2.5); -- threshold
port(terminal a: electrical; -- analogic in
signal s : out std_logic); -- digital out
end comparator;
This is the error:
ncvhdl_p: *E,MISCOL (comparator_ent.vhdl,9|14): expecting a colon (':')
87[4.3.3] 93[4.3.2].
That seem easy but I compare with others code on the web and I find no
error. Furthermore I noted that the key word 'terminal' is not in color
like the others key words. Maybe its a library issue, I don't know...
Can you help please ??
Attach your VHDL file (as a *.vhd or a *.vhdl file).
It does not make sense to fiddle around with code snippets...
sebgimi wrote:
> Furthermore I noted that the key word 'terminal' is not in color like
Its a syntax-highlighting issue of your editor. What toolchain do you
use?
von sebgimi (Guest)
Thank you for your answer!
I know that just the code of the entity does not make sense, I did that
to limit the number of errors and to make sure I use the right library
and syntaxe of vhdl-ams.
The complet code is following:
port( terminal a : in Electrical; -- analogic in
end entity comparator;
architecture archi of comparator is
quantity v across a;       -- across quantity to ground
begin
     s <= `1' when v'Above(level) -- v > level
     else `0';                    -- v < level
end architecture archi;
Now, when I compile the whole code 9 errors are occuring (in
attachment)...
Do you know from where these errors come and how to fix them?
For information I use ncvhdl/ncsim toolchain.
Thank for your help!
von sebgimi (Guest)
I forgot libraries declaration:
library ieee;
Maybe I do not use the right libraries??
And I note that the word 'terminal' is not in color either in my last
post so it is not an issue from the toolchain I guess.
von Alberto L. (Guest)
Hello Sebastian,
To make an ideal comparator in vhdl-ams is a simple task...
I add here my VHDL-ams code. Then depending if you want to have
threshold you can comment the last line or not.
You can find the full code on https://miscircuitos.com/ideal-comparator
library ieee, std;
    GENERIC(
        Vthres : REAL := 0.1  --threshold
    PORT(
        TERMINAL Vin : ELECTRICAL;
        TERMINAL Vref : ELECTRICAL;
        result : out std_logic
ARCHITECTURE vhdlams of comparator IS
      QUANTITY Volt ACROSS Vin TO Vref;
BEGIN
    --result &lt;= '1' when (Vin &gt; Vref) else '0'; --without threshold
    result &lt;= '1' when Volt'above(Vthres) else '0'; --With threshold
END vhdlams;
I hope it helps to anyone :)
Regards
Alberto
