Forum: µC & Digital Electronics RFM70 works not relably
von Hans Hamster (Guest)
there are some infos concerning RFM70 but I haven't found what I was
looking for.
I have connected 2 RFM70 to 2 ATXMEGA 128 and it works pretty well and
at reasonable distances (2 floors) but only when sender and receiver
aren't moving. When I walk around with the receiver some data pakets are
lost. My program always has the auto-ack-function enabled. Also I tried
the auto-retransmission function. Then, after 15 tries of this function,
I switched on the Re-Use mechanism (REUSE_TX_PL) with a timeout (without
switching off auto retransmission). This didn't work either. Still some
pakets are lost.
Sometimes, the receicer blocks and I can make it work again by a reset
of the processor (but this is not my main problem)
For my final purpose I need very reliable data transfer and the receiver
will move around.
Does anybody know whether successful auto-retransmission causes an
interrupt? Thats not mentioned in the instructions.
Does anybody have a suggestion how to make these transmissions safer?
Shall I flush the transmission buffer and start transmission again after
15 tries of the auto-retransmission function? can it be a hardware
problem (the parts are only plugged together but this seems to be OK).
Thanks for any suggestions!!
