//////////////////////RAM MODULE/////////////////////////// module input_ram (en, addr, data); // input clk; input en; input [6:0] addr; output reg [7:0] data; always @(*) begin if (en) begin case(addr) 7'b000: data = 8'b00110001; 7'b001: data = 8'b00010000; 7'b010: data = 8'b00100000; 7'b011: data = 8'b11101101; 7'b100: data = 8'b11100011; 7'b101: data = 8'b00110011; 7'b110: data = 8'b11110111; 7'b111: data = 8'b00111011; 7'b1000: data = 8'b00110001; 7'b1001: data = 8'b00010000; 7'b1010: data = 8'b00100000; 7'b1011: data = 8'b11101101; 7'b1100: data = 8'b11100011; 7'b1101: data = 8'b00110011; 7'b1110: data = 8'b11110111; 7'b1111: data = 8'b00111011; 7'b10000: data = 8'b00110001; 7'b10001: data = 8'b00010000; 7'b10010: data = 8'b00100000; 7'b10011: data = 8'b11101101; 7'b10100: data = 8'b11100011; 7'b10101: data = 8'b00110011; 7'b10110: data = 8'b11110111; 7'b10111: data = 8'b00111011; 7'b11000: data = 8'b00110001; 7'b11001: data = 8'b00010000; 7'b11010: data = 8'b00100000; 7'b11011: data = 8'b11101101; 7'b11100: data = 8'b11100011; 7'b11101: data = 8'b00110011; 7'b11110: data = 8'b11110111; 7'b11111: data = 8'b00111011; 7'b100000: data = 8'b00110001; 7'b100001: data = 8'b00010000; 7'b100010: data = 8'b00100000; 7'b100011: data = 8'b11101101; 7'b100100: data = 8'b11100011; 7'b100101: data = 8'b00110011; 7'b100110: data = 8'b11110111; 7'b100111: data = 8'b00111011; 7'b101000: data = 8'b00110001; 7'b101001: data = 8'b00010000; 7'b101010: data = 8'b00100000; 7'b101011: data = 8'b11101101; 7'b101100: data = 8'b11100011; 7'b101101: data = 8'b00110011; 7'b101110: data = 8'b11110111; 7'b101111: data = 8'b00111011; 7'b110000: data = 8'b00110001; 7'b110001: data = 8'b00010000; 7'b110010: data = 8'b00100000; 7'b110011: data = 8'b11101101; 7'b110100: data = 8'b11100011; 7'b110101: data = 8'b00110011; 7'b110110: data = 8'b11110111; 7'b110111: data = 8'b00111011; 7'b111000: data = 8'b00110001; 7'b111001: data = 8'b00010000; 7'b111010: data = 8'b00100000; 7'b111011: data = 8'b11101101; 7'b111100: data = 8'b11100011; 7'b111101: data = 8'b00110011; 7'b111110: data = 8'b11110111; 7'b111111: data = 8'b00111011; 7'b1000000: data = 8'b00110001; default: data = 8'b0000_XXXX; endcase end end endmodule //////////////another rom module in which weight is stored///////////// module weight_ram (en, addr, weight); // input clk; input en; input [6:0] addr; output reg [7:0] weight; always @(* ) begin if (en) begin case(addr) 7'b000: weight = 8'b11111011; 7'b001: weight = 8'b00001110; 7'b010: weight = 8'b11100000; 7'b011: weight = 8'b11110011; 7'b100: weight = 8'b11110011; 7'b101: weight = 8'b11100110; 7'b110: weight = 8'b11101100; 7'b111: weight = 8'b11110110; 7'b1000: weight = 8'b11111001; 7'b1001: weight = 8'b00000010; 7'b1010: weight = 8'b11111011; 7'b1011: weight = 8'b00001100; 7'b1100: weight = 8'b11101101; 7'b1101: weight = 8'b00011000; 7'b1110: weight = 8'b11100010; 7'b1111: weight = 8'b00001011; 7'b10000: weight = 8'b11111011; 7'b10001: weight = 8'b00000100; 7'b10010: weight = 8'b11101001; 7'b10011: weight = 8'b11101101; 7'b10100: weight = 8'b00010011; 7'b10101: weight = 8'b00011110; 7'b10110: weight = 8'b11110100; 7'b10111: weight = 8'b00001100; 7'b11000: weight = 8'b00011000; 7'b11001: weight = 8'b00011001; 7'b11010: weight = 8'b11100101; 7'b11011: weight = 8'b11100010; 7'b11100: weight = 8'b11101011; 7'b11101: weight = 8'b00011000; 7'b11110: weight = 8'b11100110; 7'b11111: weight = 8'b11111011; 7'b100000: weight = 8'b00011101; 7'b100001: weight = 8'b00000010; 7'b100010: weight = 8'b00001100; 7'b100011: weight = 8'b11110100; 7'b100100: weight = 8'b00001100; 7'b100101: weight = 8'b00010101; 7'b100110: weight = 8'b11100001; 7'b100111: weight = 8'b00010000; 7'b101000: weight = 8'b00011111; 7'b101001: weight = 8'b00010000; 7'b101010: weight = 8'b11110010; 7'b101011: weight = 8'b00010011; 7'b101100: weight = 8'b11100111; 7'b101101: weight = 8'b11111101; 7'b101110: weight = 8'b00011010; 7'b101111: weight = 8'b11110011; 7'b110000: weight = 8'b11110010; 7'b110001: weight = 8'b11101000; 7'b110010: weight = 8'b11100001; 7'b110011: weight = 8'b00001011; 7'b110100: weight = 8'b11101110; 7'b110101: weight = 8'b11110001; 7'b110110: weight = 8'b11111111; 7'b110111: weight = 8'b11100011; 7'b111000: weight = 8'b00000101; 7'b111001: weight = 8'b11101001; 7'b111010: weight = 8'b00000110; 7'b111011: weight = 8'b00001101; 7'b111100: weight = 8'b11100111; 7'b111101: weight = 8'b11111010; 7'b111110: weight = 8'b00001100; 7'b111111: weight = 8'b11111011; 7'b1000000: weight = 8'b11100011; 7'b1000001: weight = 8'b00000010; 7'b1000010: weight = 8'b00001010; 7'b1000011: weight = 8'b00000001; 7'b1000100: weight = 8'b00011100; 7'b1000101: weight = 8'b00000110; 7'b1000110: weight = 8'b00011010; 7'b1000111: weight = 8'b11101001; default: weight = 8'b0000_XXXX; endcase end end endmodule /////////////////Booth multiplier Multiplier to multiply data and weight //////////////// module multiplier(prod, busy, mc, mp, clk, start); output [15:0] prod; output busy; input [7:0] mc, mp; input clk, start; reg [7:0] A, Q, M; reg Q_1; reg [3:0] count; wire [7:0] sum, difference; always @(posedge clk) begin if (start) begin A <= 8'b0; M <= mc; Q <= mp; Q_1 <= 1'b0; count <= 4'b0; end else begin case ({Q[0], Q_1}) 2'b0_1 : {A, Q, Q_1} <= {sum[7], sum, Q}; 2'b1_0 : {A, Q, Q_1} <= {difference[7], difference, Q}; default: {A, Q, Q_1} <= {A[7], A, Q}; endcase count <= count + 1'b1; end end alu adder (sum, A, M, 1'b0); alu subtracter (difference, A, ~M, 1'b1); assign prod = {A, Q}; assign busy = (count < 8); //assign temp = ((busy==0 && clk ==1) ? prod : 16'bx); initial begin $monitor($time,"prod=%b, busy==%b, mc=%b, mp=%b, clk=%b, start=%b",prod, busy, mc, mp, clk, start); end endmodule //The following is an alu. //It is an adder, but capable of subtraction: //Recall that subtraction means adding the two's complement-- //a - b = a + (-b) = a + (inverted b + 1) //The 1 will be coming in as cin (carry-in) module alu(out, a, b, cin); output [7:0] out; input [7:0] a; input [7:0] b; input cin; assign out = a + b + cin; endmodule ////////////////////////////////////Testbench/////////////////////// module top_tst; // Inputs reg clk; reg en; reg start; reg [6:0] address; // reg [15:0] temp; // Outputs wire [15:0] mux_out,multiplied; wire [7:0] data; wire [7:0] weight; wire busy; // Instantiate the Unit Under Test (UUT) top_module uut ( // .multiplied(multiplied), .mux_out(mux_out), .data(data), .weight(weight), .clk(clk), .en(en), .start(start), .address(address), .busy(busy) ); initial begin clk = 0; en = 0; address = 7'b0; en=1; $monitor ($time,"clk=%b,en=%b,start=%b,address=%b,data=%b,weight=%b",clk,en,start ,address,data,weight); end always #2 clk=~clk; always @ (data or weight) begin start=1; #4 start=0; end always @ (busy==0) begin address=address+7'b1; end endmodule Sir i am new to verilog and and i am getting problem while simulation help me to come out from this situation i will explain the scenario of my code data and weight are two input which is stored in rom at different address and i used booth multiplier because some of my input are signed and what i am doing that at adress=0000000 my data and weight load on dataline and after multiplying when my answer of multipier is available i want to increase my adress=0000001 so that next data and weight must be available and process repeate but dont know where i am doing mistake in test bench sir please help me to come out this problem
