Forum: FPGA, VHDL & Verilog How to write the 125 Mhz frequancy in a testbench vhdl language
von Abdallah  . (Company: Home) (my_name)
I'm beginner in VHDL,
I have to devide the frequency from 125 Mhz to 1 Hz
for that I used this code to generate the 1s clock
---   generate the 1s clock   ---
process(clk,rst)
  begin
    if rst='1' then
      cnt<=1;
    else
      cnt<=cnt+1;
    end if;
    if cnt<=62000000 then
      clk_s<='0';
    else
      clk_s<='1';
    end if;
    if cnt=125000000 then
      cnt<=1;
    end if;
  end process;
the probleme is what's the value of clock (clk) I should define in
testbensh ( is it 8ns ??)
help me please!   thank you.
Abdallah.
von guest user (Guest)
Dont u have a calculator? The clockperiod is 1/(125*10e6 Hz)=8ns
thank you for your response guest!
I just confused because the simulation didn't provide the good result.
it provide clock of 0.5 second not 1 second.. where is the probleme!!!!
this is my code
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity one_second is
  port(clk_in:in bit;
      s:out bit);
end one_second;
architecture Behavioral of one_second is
signal cnt:integer:=1;
begin
  process(clk_in)
  begin
    cnt<=cnt+1;
    if cnt<=62500000 then
      s<='0';
    else
      s<='1';
    end if;
      cnt<=1;
    end if;
  end process;
end Behavioral;
von PittyJ (Guest)
There is no raising_edge.
Try something like this:
if rst = '1' then
  Cntr <= (others => '0');
Elsif clk = '1' and clk'event then
   Cntr <= cntr +1;
--add your stuff;
End if;
von lkmiller (Guest)
> where is the probleme!!!! this is my code
One problem is, that the process is triggered with each change on
clk_in, so the counter counts at each rising and each falling edge of
clk_in.
But the much bigger problem is, that you do not know what you are doing!
Have a look how others write a counter and check your solution against
it.
BTW: your counter will work only in simulation. In real hardware it is a
combinational loop...
That's true about the counter, I change its value to 125E06 for each
front.
it's work only when I decreases the counter to 125E03 with decreases of
clock to 8us, or counter <= 125 with clock of 8ms..............
biiiiiiiiiiiig probleme when counter<=125000000 and clock=8ns.......
the result is more than anarchy..(because of the computer!!!)
what if I implement it to the board,does it work!!!
--- what's your opinion?
thany you.
   By the way M.lkmiller I really know what I do although that I'm still
beginner
   ....any way Thank you very much
library IEEE;
  port(clk_in:in bit;
      s:out bit);
end one_second;
begin
  process(clk_in)
  begin
    cnt<=cnt+1;
    if cnt<125000000 then
      s<='0';
    else
      s<='1';
    end if;
    if cnt=250000000 then
      cnt<=1;
    end if;
  end process;
end Behavioral;
: Edited by User
Think in hardware. What are counters synthesise to?
Do u know FF that works with rising AND falling edge? No? Me too!
Okay it's done, thanks to ALLAH
this is the finale code with the description in the attachment file
I hope that you give your opinion about the code and why not correct my
false steps.. thanks a lot.
-| Controle d'un feu de circulation en utilisant les Machines d'Etats
-| Control of the traffic light using machines States
library IEEE;
---    Entity              ---
entity feu_circulation is
  port(  clk,rst,tst,a: in bit;
      r1,r2:out std_logic_vector(2 downto 0));
end feu_circulation;
---    Architecture          ---
architecture feu_circulation of feu_circulation is
  type etat is(R_V,R_O,V_R,O_R,O_O);
  signal p_etat,s_etat:etat;
  signal clk_etat,clk_s:bit:='0';
  signal cnt,tmps:integer:=1;
begin
---    Changement de l'Etat Presente vers l'Etat Suivante            ---
  process(rst,clk_etat)
  begin
    if rst='1' then
      p_etat<=R_V;
    elsif(clk_etat'event and clk_etat='1') then
      p_etat<=s_etat;
    end if;
  end process;
---Definition de l'Etat Suivante et les valeurs des Signaux de Sortie
---            Changing Presente State to Next State
  process(p_etat,a,tst)
  begin
    case p_etat is
      when R_V =>r1<="100";  r2<="010";
        if a='0' then
          s_etat<=R_O;
        else
          s_etat<=O_O;
        end if;
        if tst='0' then  tmps<=30;  else  tmps<=1;  end if;
      when R_O =>r1<="100";  r2<="001";
        if a='0' then
          s_etat<=V_R;
        else
          s_etat<=O_O;
        end if;
        if tst='0' then  tmps<=5;  else  tmps<=1;  end if;
      when V_R =>r1<="010";  r2<="100";
        if a='0' then
          s_etat<=O_R;
        else
          s_etat<=O_O;
        end if;
        if tst='0' then  tmps<=45;  else  tmps<=1;  end if;
      when O_R =>r1<="001";  r2<="100";
        if a='0' then
          s_etat<=R_V;
        else
          s_etat<=O_O;
        end if;
      when O_O =>r1<="001";  r2<="001";
        if a='0' then
          s_etat<=R_V;
        else
          s_etat<=O_O;
        end if;
        tmps<=1;
    end case;
  end process;
---  Génération de l'horloge de 1s de période (clk_s) à partir de
l'horloge de 8ns de période (clk)
---        Generation of the clock period of 1s (clk_s) from the clock
period of 8ns (clk)      ---
  process(clk,rst)
  begin
    if rst='1' then
      cnt<=1;
    else
      cnt<=cnt+1;
    end if;
    if cnt<125 then--- to use clock periode of 8ns, use cnt<125000000.
note: It doesn't work in ISE Simulation
      clk_s<='0';   -- to use clock periode of 8us, use cnt<125000.
    else         -- to use clock periode of 8ms, use cnt<125.
      clk_s<='1';
    end if;
    if cnt=250 then--- to use clock periode of 8ns, use cnt<250000000.
      cnt<=1;     -- to use clock periode of 8us, use cnt<250000.
    end if;       -- to use clock periode of 8ms, use cnt<250.
  end process;
---  Géneration de l'horloge de sorite (clk_etat) d'une période qui
varie selon les 3 Modes   ---
---    Generation of the output clock (clk_etat) of a period which
varies from 3 Modes      ---
  process(clk_s,rst,a,tst)
    variable temps:integer;
    variable ok:bit:='1';
  begin
    if tst='1' then
      ok:='1';
    end if;
    if rst='1' then
        ok:='1';
    elsif a='0' then
        if ok='1' then
          temps:=tmps;
          ok:='0';
          clk_etat<='0';
        end if;
        if clk_s'event and clk_s='1' then
          temps:=temps-1;
          if temps=0 then
            ok:='1';
            clk_etat<='1';
          end if;
        end if;
    end if;
    if a='1' then
      clk_etat<=clk_s;
      ok:='1';
    end if;
  end process;
    -----  Abdallah ----  Abdallah ----  Abdallah ----  Abdallah ------
Ohh man...
There are many good books out there. Try to get one.
This code is terrible...
