Forum: ARM programming with GCC/GNU tools ARM Integrator/CP and general portability
von Jakob H. (holderbaum)
Hi folks,
I started some simulations with QEMU, targeting developments for the ARM
architecture.
The list of supported architectures and development boards presents the
(in the title stated) Integrator/CP board as one of the leanest eval.
boards, regarding to the amount of external hardware.
In the context of my masters thesis I'm building a virtual prototype of
a distributes measurement system. In the current evaluation phase I am
thinking about different hardware architectures for the implementation
of the nodes of the measurement network.
Now to my core question. How big is the difference between the ARM
Integrator/CP and other distinct ARM926E architecture implementations
from Atmel or other companies.
Since I am experienced in embedded development/hardware engineering but
totally new to the ARM-based architecture, I am lacking the professional
competence to evaluate the extend of the differences between the various
implementations of this architecture.
The features I need to use boil basically down to one or two UARTs and a
general amount of GPIO, so no fancy CPU related stuff.
Maybe it is possible to write the firmware in such an encapsulated way,
that a platform switch only impacts the mapping of the used registers
and a customization of the linker script and the startup assembler?
Please provide me with your experiences on portability in the context of
ARM.
Cheers and thanks in advance
Jakob
: Edited by User
von Dr. Sommer (Guest)
That CPU related stuff is hardly a problem, the UART and GPIO stuff,
however, is:
The processor core of all implementations of a single ARM architecture
such as ARM926 (which is old/deprecated, btw) is identical from the
software viewpoint (i.e. instruction set etc.). There are some
variations of supported features (such as FPU, Jazelle, MMU, ...), these
should be documented in the ARMv5 Architecture Reference Manual. So if
you take care which of those features you use, your code should be
binary-compatible to all implementations supporting the respective
features.
Peripherals, such as UART and GPIO pins, are a different story; every
microcontroller manufacturer defines his own peripherals and interfaces
to the processor core. If you want your code to be portable across
multiple implementations, you need to define an abstraction layer around
the peripheral accesses, and exchange its implementation depending on
the microcontroller you wish to compile for. There are ready made
libraries and RTOS that do this.
Remember, ARM only defines processor cores, and not peripherals like
UART and GPIO.
PS: Why don't you build an actual, instead of a virtual, prototype with
a lean, cheap and also modern eval board such as the STM32F4 Discovery
Board (Cortex-M4F, ARMv7M, ~15€) while encapsulating the hardware
accesses into an exchangeable hardware access layer? This allows you to
use the modern ARMv7M architecture, gets rid of the need for platform
support by qemu and allows you to presend an actual prototype. Keil
µVision should also include a simulator for that platform, IIRC.
Hi Dr. Sommer and thanks for your detailed replies.
Your explanation of the ARM architecture makes sense, the abstractions
for the hardware access you mentioned where kind of the planned way to
go for me.
I thought about building an actual prototype, but since I want to create
a distributed system, this setup would become rather big.
My fear is, that the whole debugging process of a physical
implementation with a shared BUS and multiple controllers will consume
much more time than running on emulated hardware.
I got the impression, that debugging possibilities are more extensive on
a virtual platform. Pleae correct me if I am wrong with one of my theses
here.
You made a strong point with "[..] and allows you to presend an actual
prototype", I must truly admit that. :)
Have a nice day
Jakob
: Edited by User
> here.
I don't know about the virtual platform, but on the Cortex-M devices you
can do step-by-step debugging, code breakpoints, data watchpoints,
memory examining, and some tracing stuff i don't know much about. This
might already be sufficient.,,
The question is whether working with an emulator is more
straight-forward. The compiling & linking stuff is probably equivalent,
but with an actual prototype you can interface actual hardware such as
LCD's, sensors etc.
