Forum: FPGA, VHDL & Verilog VHDL Code help
von Tai T. (john9686)
Ok so when I run Isim through xilink I get this:
Simulator is doing circuit initialization process.
at 0 ps, Instance /testbench/uut/ : Warning: NUMERIC_STD."<": metavalue
detected, returning FALSE
ERROR: In process functionT.vhd:25
 Target Size 10 and source size 20 for array dimension 0 does not match.
Is it referring to "z <= y * 3;" ????
Code:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity functionT is
    port(
        clk: in std_logic;
        switches: in std_logic_vector(9 downto 0);
        output: out std_logic_vector(9 downto 0)
end functionT;
architecture ARCH of functionT is
--signals
constant A: unsigned(9 downto 0):=("0110101001"); -- A=425
signal B: unsigned(9 downto 0);
signal sig512: unsigned(9 downto 0):=("1000000000");
signal T: unsigned(9 downto 0);
signal x, y, z: unsigned(9 downto 0);
begin
    B <= unsigned(switches); --something like that
    x <= A when A>sig512 else sig512;
    y <= x when x<B else B;
    z <= y * 3;
    T <= z(7 downto 0) & "00";
    output <= std_logic_vector(T);
end ARCH;
: Edited by Admin
von Olga (Guest)
IF it is line 25 then yes. But I'm not going to count it. It's your
task to tell us, which line the error is referring to.
That is line 25.
Why would I be receiving this error in isim?
von Gustl B. (-gb-)
Y is 10 bits, 3 is at least 2 bits. So the result 1023*3=3069 is
101111111101 is 12 bits but z is only 10 bits so z is too short. The
error says z should be 20 bits long, not 12. I cant say why, but just do
it and use the last 8 bits.
Thanks I have it working. The only problem now is how to divide the "T"
by 4 so I get the right "output". With this code T=672 and ouput=672,
168 is the correct output meaning I need to divide by 4.
CODE:
library IEEE;
entity functionT is
    port(
        clk: in std_logic;
        output: out std_logic_vector(19 downto 0)
end functionT;
--signals
signal A: unsigned(9 downto 0):=("0110101001"); -- A=425
signal B: unsigned(9 downto 0):=("0011100000"); -- B=224
signal sig512: unsigned(9 downto 0):=("1000000000"); -- sig512=512
signal T: unsigned(19 downto 0);
signal x, y: unsigned(9 downto 0);
signal z: unsigned(19 downto 0);
begin
    x <= A when A>sig512 else sig512; --Maximum
    y <= x when x<B else B; --Minimum
    z <= y * 3;
   T <= z(17 downto 0) & "00";
end ARCH;
: Edited by Admin
Sorry with out the whole picture it wouldn't make sense. Attached
expression I was working on
I need to mutilate by 0.75
so multiply by 3 then divide by 4
Tai Tai wrote:
> The only problem now is how to divide the "T" by 4
Why don't you simply try it this way:  output <= std_logic_vector(T/4);
That will work, because an unsigned division by 4 is just "truncating
the last two bits"...
BTW: why not using integer datatypes?
library IEEE;
entity functionT is
port(
  clk: in std_logic;
  inA: in std_logic_vector(19 downto 0),
  inB: in std_logic_vector(19 downto 0),
  output: out std_logic_vector(9 downto 0) -- can never be longer than A or B
end functionT;
--signals
signal A: integer := 425; -- initialazation makes no sense
signal B: integer := 224; -- because A nd B are not in registers!
signal T, x, y: integer;
begin
  -- convert inputs to integers
  A <= to_integer(unsigned(inA));
  B <= to_integer(unsigned(inB));
  -- do the calculation
  x <= A when A>512 else 512; -- Maximum
  y <= x when x<B   else B;   -- Minimum
  T <= (y*3)/4;               -- *0.75
30
  -- convert back for output
31
  output <= std_logic_vector(to_unsinged(T,10));
32
end ARCH;
For the magic conversions between vectors and integers see the picture
there:
http://www.lothar-miller.de/s9y/categories/16-Numeric_Std
: Edited by Moderator
von Gustl B. (-gb-)
Why don't you just write
T<=z(9 downto 0);
Because attaching "00" is a left shift with 2 digits means you multiply
with 4.
I also see no need for T to be 20 bits long when your right output is
168 you only need 8 bits.
> T<=z(9 downto 0);
If at all such a trick, then it should be
   T <= z(11 downto 2)
Because then the last two bits are truncated (whats ok for an unsigned
division by 4). But all in all I prefer the z/4 style...
von Gustl B. (-gb-)
Hello,
he has:
z <= y * 3;
so T = z*4. And the output is factor 4 too high (so he says), so he
could just leave away the &"00" and gets it perfectly? I think he
accidentially multiplies z by 4.
> (so he says)
Maybe he's wrong...
Yeah thanks for all your input. This the code I have working perfectly.
Code:
library IEEE;
entity functionT is
    port(
        clk: in std_logic;
end functionT;
--signals
signal A: unsigned(9 downto 0):=("0010111001"); -- A=185
signal B: unsigned(9 downto 0):=("0100100100"); -- B=292
begin
    z <= y * 3; --Multiple by 3
    output <= std_logic_vector(z/4); --Divide by 4
end ARCH;
: Edited by Admin
