Forum: µC & Digital Electronics MCP7940N: MFP frequency out and calibratio
von Hartl192 (Guest)
I'm not sure how the MFP pin works if I set the SQWE to '1' and the RS2
bit to '1'.
Which output frequencies can I select with <RS1:RS0>? Is the frequency
64Hz regardless of what I do with R0 and R1?
My aim is to calibrate the oscillator. I made myself a counter with a
GPS modem as reference and a gating time of 60 seconds.
Is it possible to output the 32.768Hz (RS<2:0> = 011) signal and count
the pulses for 60s and then calculate the calibration factor? After
writing the calibration factor in the calibration register I'll output a
calibrated wave by setting RS2 to '1' and measure if the calibration is
ok.
Is this a good way to do the calibration? Or can you recommend me
another way? My best device to measure time/frequency is the
GPS-frequency counter.
Thank you in advance for your help.
http://ww1.microchip.com/downloads/en/DeviceDoc/25010E.pdf
I measured the frequency of the MPF output and it is 32767.166666Hz and
this produces an error of about 2 second every day. Now I want to use
the calibration function but I’m not sure if calculated the calibration
factor right.
I measured 1966030 pulses in one minute, but it should be
60*2^15=1966080.
1966080-1966030=50, so I have to add 50 pulse per minute. Does it means
that I have to write 25 (0b00011001) in the calibration register?
