Forum: FPGA, VHDL & Verilog Asynchronous shift register
Author: Steve (Guest)
Hallo all
I have the data in this pattern which I want to be shifted (32 bits) :
0x00000001
0x00000200
0x00030000
0x04000005
This data transfer happens in a single clock pulse . i.e .I get four 32
bit data for every clock pulse (each has a single delta delay).This is
basically a RGB data. Each 24 bit forms a pixel.
I want this data to be shifted continuously into a 24 bit register.So
that I can create an image using the above data.
I am looking for a solution for this . Please help.
Thanks in advance
Steve.
Clarify your specification. I don't have any clue with the information
you provided...
Where does the data come from? What data format do you have? What do you
want to do with that data? Is there a pixel clock or any other
validation signal provided with the data stream? What data rate do you
have?
There is no such thing like an "asynchonous shift register". So what do
you want really?
Hi
I have to read the data from an Interface which is in Hex Format.I dont
have a pixel clock. I am just using the rgb data and nothing else.
I want to convert the 32 bit stream to 24 bits so that I can convert
that into an image file.
If you see the above stream I have mentioned . The second pixel starts
at the end of first data. And that continues. I want to separate that.
Thanks for your response.
Author: Achim S. (Guest)
Steve wrote:
> 0x00000001
> 0x00000200
> 0x00030000
> 0x04000005
So you want to resort this into
000001
020000
000000
000300
That should not be too hard: you need a little state machine, which
reads 3 32bit words, makes some intermediate storage of it and puts it
out as 4 24bit words.
But due to the following statement, your task is impossible:
Steve wrote:
> I dont
If there is no information, whether the actual data at the input is the
first valid 32bit value or the second valid 32bit value (or invalid data
as the signals are switching between the first and the second value),
then there's no way to read in the data correctly.
Your data at least has to be synchronous to some clock, and you need
some indicator, if you're just looking at the first or at the second
32bit value.
What interface is in hex format?
What language? I assume it is Verilog due to this term:
So what you get each "cycle" is 128 bit of information?
Those 128 bit contain 5.33333 pixels...
Like this (i kicked off the C-isch 0x):
> 000000_01
> 0000_0200
> 00_030000
> 040000_05
And i coould continue your series like that
> 0000_0600
> 00_070000
> 080000_09
> 0000_0a00
> 00_0b0000
> 0c0000_0d
Shifting is not possible without a clock. I think i mentioned that
already...
: Edited by Moderator
  • [vhdl]VHDL code[/vhdl]
