Forum: ARM programming with GCC/GNU tools GNU issues for cpp
Author: Sujit P. (sujit_p)
GCC issue 1:
We are working on the STM32F0 series, where the src code is in C++ and
the compiler used is the GCC ARM (version 4.4.1) which compiles fine.
However when we changed the GCC compiler to 4.7.3 we are observing
linker issues as below:
undefined reference to '_isatty'
Can anyone suggest a solution for the same?
GCC issue 2:
We are observing that the compiler is behaving weird while dividing
variables.
i.e.
var1 = var2/2  => OK
var1 = var2/3  => FAIL! (runtime issue, compiles fine)
var1 = var2/8  => OK
var1 = var2/6  => FAIL! (runtime issue, compiles fine)
Seems it behaves weird for some specific values of the divider.
We have verified the issue thru thorough testing so theres no doubt left
about the observation.
Now we are trying to find a soln/workaround for the same.
Any such experiences with the GCC ARM compiler would be helpful.
Author: Dr. Sommer (Guest)
1 useful
Define an empty dummy function:
void _isatty () {}
, compile & link. Then disassemble the code and see where it used, and
remove that code.
Sujit P. wrote:
> var1 = var2/8  => OK
This will be optimized to a bitshoft (var2 >> 3)
Did you specify the correct ARM Core (Cortex-M0)? That core does not
have a hardware division unit, you have to ensure the compiler generates
software division code.
can any one have a working CPP template.
so that i can use that as an example to proceed.
Author: Meth (Guest)
You don't need a "CPP template", you need a "project template". Correct
compiler options and linker file etc.
Since you not even replied to the question which core you're using, it's
obviously not very urgent, and you'll be fine after taking your time
reading the documentation.
Cortex M0
and wrking on STM32F051.
