1 | library ieee;
2 | use ieee.std_logic_1164.all;
3 | --use ieee.std_logic_arith.all;
4 | use ieee.std_logic_unsigned.all;
5 | entity SRAM is
6 | generic(width:integer:=4;depth:integer:=32);
7 | port(
8 | Clock:in std_logic;
9 | Enable:in std_logic;
10 | Read:in std_logic;
11 | Write:in std_logic;
12 | Read_Addr:in std_logic_vector(4 downto 0);
13 | Write_Addr: in std_logic_vector(4 downto 0);
14 | Data_in: in std_logic_vector(3 downto 0);
15 | Data_out: out std_logic_vector(3 downto 0));
16 | end SRAM;
17 |
18 | architecture behav of SRAM is
19 | type ram_type is array (0 to 31) of
20 | std_logic_vector(3 downto 0);
21 | signal tmp_ram:ram_type;
22 | begin
23 | process(clock,read)
24 | begin
25 | if(clock'event and clock='1') then
26 | if enable='1' then
27 | if read='1' then
28 | data_out<=tmp_ram(conv_integer(read_addr));
29 | else
30 | data_out<=(data_out'range=>'Z');
31 | end if;
32 | end if;
33 | end if;
34 | end process;
35 | process(clock,write)
36 | begin
37 | if(clock'event and clock='1') then
38 | if enable='1' then
39 | if write='1' then
40 | tmp_ram(conv_integer(write_addr))<=data_in;
41 | end if;
42 | end if;
43 | end if;
44 | end process;
45 | end behav;
I got this code for RAM online.
When i run it in MODELSIM the writing takes a complete clock cycle(if
clock starts with a +ve edge) and
reading takes 1 and 1/2 clock cycles(if clock starts with a +ve edge).
could anyone explain why is it so?
and also pls give me a way to make the read and write cycle within a
single clock cycle.
