Forum: FPGA, VHDL & Verilog Train Ticket Machine using VHDL
von Schmidt n. (schmidt_n)
Hello. I am new in VHDL. I try to create train ticket machine using
vhdl. It have 3 destination and all destination have fee. When user
insert money with same of fee, ticket will out and no change but if user
enter extra money than fee, ticket will out also with change.When i run
the simulation all output does not appear but it appear UUU. Anybody can
help me with my code,please. Thanks. God bless you.
von PittyJ (Guest)
You should watch the p_State signal, and look, why it dows not get in to
the state, which sets the return.
von dennis (Guest)
Hello,
why aren't you Reset "ticket, money_sum and retrn"?
Add them to your rst or reset them in the State before.
Mfg Dennis
Thanks for reply. i already look p_state and i don't know which line the
error.
I already add reset ticket,money_sum and retrn but i got error after
compile it.Assume that I am zero in vhdl. Thanks
Schmidt n. wrote:
> Anybody can help me with my code,please.
Your code is doing exactly what you described...
You can have a closer look to the signals inside the entity
trainticket_machine. Just dig around a littlte bit in the simulators
projekt structure (the projekt window is on the left halnd side to your
screenshot)...
Money_sum is missing in this sensitivity list, so the simulation is
wrong:
PROCESS (p_state,Cancel,RM1,RM2,RM5,KL_station,Mid_station,Klang_station)
But after adding it you will find an issue with a combinational loop
with all those statements:
    Money_sum <= Money_sum + 1; -- also +2 and +5...
BTW:
Never ever use all of the arithmetic libs:
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
You will have some definitions doubled and you will encounter courious
problems with that...
So, why not starting with a much simpler project like an counter or
something else?
Thanks. I already add Money_sum into my simulation.
BTW if i never use those library what should I used because when I
enable it my code have many errors.
Yes, I am not much know about VHDL. Thanks for advice.
> disable it my code have many errors.
Start thinking, not copying.
The numeric_std has all to handle conversions from vector types to
integer and to deal with vectorized calculations. You just cannot add
two std_logic_vector directly, but instead you must use the signed
or unsigned vectors.
All in all its absolutely no rocket science and its done by millions of
students before. Think about it...
One thing more:
>     Money_sum  :  INOUT STD_LOGIC_VECTOR (3 DOWNTO 0)
Using INOUT just for laziness or for some kind of "short and compact
code"?
In which book did you find this? Throw it away!
Never ever try to "simplify" your beginners code with such dirty tricks.
Instead have a look inside books of Peter Ashenden, he is very close to
the VHDL standards because he works in the VHDL standardization panel.
Alright. Thanks for your response and adviced
